220 Rosa Master
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Topic: 220 Rosa Master
    Posted: 03 Jul 2026 at 9:37pm
   Is the Rosa Master on a 220 a four or a two roller??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 4:11am
"DC" is a 4-roller .310" diameter pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 8:20am
   Thanks Dr, that should work on a 200, the same firing order?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 8:50am
Should be fine and overfueled. Drive shaft end is splined, so you have to find a DC shaft the right length. There are two shaft length possibilities.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 11:30am
have some dc629 if needed , 631 are hard to find,5o7 7six6 o551
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2026 at 8:36am
You will have to talk to a pump station - the drive shaft for the 426 is too long as there is a spacer there.  I would suggest asking Ed as he would have the #. I got one thru the old Columbus diesel many decades ago after discovery of the drive issue. Ed Elgin and Nobel Harrison set up a many 'floating head roosas' in the late 60-early 70's. They had a special cam ring - some used a .35" head - removed the transfer pump and delivery valve - and ran a Barnes fuel supply pump at 150 psi . The front thrust button was removed and a bolt was installed via welded nut to serve as a thrust stop for the gear. they also had the leaf springs and shoes modified to give max piston travel w/o getting the short piston cross ways seized. They also had half ,I think, of the gov weights removed. These ran successfully and won a few classes at NFMS. Of course they were no match for the inline A & P pumps that followed. Imagine, .31 plungers pumping for 6 cylinders vs one .7 " + plunger per cylinder today - quite an increase eh?
