2027 Chevy truck |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3388 |
Topic: 2027 Chevy truckPosted: 20 Sep 2026 at 6:15am |
See they won't have a engine oil dipstick
I'm not short and have to use a step stool to reach the one on my 2018 truck Still doesn't seem like a good idea to me to eliminate it |
Joined: 11 Sep 2009 Location: illinois Points: 93342 |
Posted: 20 Sep 2026 at 7:43am |
for 90% of the population that never check the oil level and dont know what a dip stick is anyway... having the little idiot light that says " add oil" or "change oil" is probably a good idea..
Personally i prefer the dip stick to really tell you what you got.... Elimination of the trans dip stick was the "test" ... apparently that worked... i dont like that either.... the problem is when you CHANGE oil, exactly how much do you put back in ? Crawling under the truck and pulling a plug on a HOT RUNNING trans is not my idea of a good time.
ACinSC
Posted: 20 Sep 2026 at 8:36am |
Good point Steve! Salesman at the dealership told me " I bet you're one of those guys that checks his oil" Guess not many do like you said.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25505 |
Posted: 20 Sep 2026 at 9:57am |
but they have a computer with camera looking at the driver 24/7....... |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1434 |
Posted: 20 Sep 2026 at 11:48am |
Bad idea…
Just had to replace a temperature sender on one of my dad’s older John Deere’s, said it was about to overheat as soon as someone turned on the key. But maybe they got rid of the engine and put it to electric…. Edited by 55allis - 20 Sep 2026 at 11:48am |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1663 |
Posted: 20 Sep 2026 at 8:01pm |
Worst idea ever!!!!!!!!!!!!!
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36664 |
Posted: 21 Sep 2026 at 3:31am |
Well at least the Warranty Sleuths cannot deny warranty when engine eats all the oil and then itself. Happens quite more often than not.
ACinSC
Posted: 54 minutes ago at 6:39am |
Just read that you have the engine at idle and pull up the oil level screen. It will say if oil is low and how much to add. What could go wrong, right?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5460 |
Posted: 24 minutes ago at 7:09am |
Tell me again why I should be buying a new anything instead of keeping what I have going. There's no argument whatsoever that could convince me to but this new overpriced crap.
ACinSC
Posted: 16 minutes ago at 7:17am |
Oh Paul, you're missing out. Now I see you can opt for a little fridge under the armrest! Gotta have that!
