1984 4 wheel drive Model 5015
nhmath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhmath Quote  Post ReplyReply Direct Link To This Post Topic: 1984 4 wheel drive Model 5015
    Posted: 28 Sep 2023 at 4:56pm
Hi, When I put the 4 wheel drive lever down It does not engage the fron wheels. Please HELP. Neil
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 7:07pm
Haven’t worked on the 4x4 5015, did you follow the lever to see where it goes to make sure you don’t see something that has come loose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhmath Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 6:31am
Yes. it seems to try and lock in but at the point of lock in it looks jammed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:05pm
Can you post a picture of the linkage?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:24pm
jammed like the gears are not meshing ? ....Sometimes rolling slowly or bumping the clutch to rock the tractor will allow a gearbox to mesh. ( like a transmission).
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhmath Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 7:27am
Thanks I will give it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhmath Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 7:28am
Will do as soon as I can.
Jasonw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonw Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 5:47am
The front drive shaft is driven via a sprocket and roller chain on the rear pinion shaft. The chain or keyway for the sprocket could be broken.
