1958 HD-5G into the fold: |
Page <123> |
Codger
Thanks(1)
Posted: 11 Jan 2026 at 7:42pm |
Received alternator as updated schedule showed. Nice unit I'll get installed tomorrow if another order of blasting consumables shows up.
Seen this and it's an interesting watch: |
That's All Folks!
Codger
Posted: 13 Jan 2026 at 7:18pm |
Talked to starter rebuilder this afternoon and not going any further with the 30MT. He also recommends a 39MT to replace this one. Didn't have one but will build one up from parts for me. Less $$$ to go with the 39MT too as two of the field coils of the original starter were out of spec, and one pole shoe was cracked/busted from the starter motor being waylaid with a hammer several times. There are actually dents beat into the housing. Also discovered the cylinder block in the tractor is aluminum. Head, and flywheel housing are iron, but most everything else is aluminum.
Received blasting order today late in the afternoon so back at it tomorrow to finish up.
That's All Folks!
Les Kerf
Posted: 14 Jan 2026 at 8:27am |
Interesting!
Codger
Posted: 14 Jan 2026 at 9:47am |
Surprised me. I've seen many 3-53 Detroit engines in both iron and aluminum when in the military but this is the first civilian aluminum block I've seen. However, I don't know much history on the tractor. It was very near dark when I was pulling the starter and a magnetic work lamp wouldn't stick to the block is how I found it before looking closer and snapping photos.
That's All Folks!
Les Kerf
Posted: 14 Jan 2026 at 2:11pm |
Cool! A 'lightweight' HD5G
Codger
Thanks(1)
Posted: 14 Jan 2026 at 3:41pm |
This engine is in a Clark backhoe loader but may go into that HD5G if the 2-71 is not good. I'd like to fashion a clamshell bucket, (or tines) for the HD5G as have a lot of brush and trees to take out at some family property. I have about 1/3rd of a rake built for the 11B and once all the relatively "heavy" groundwork is done, I'd like to leave this HD5G at the property for maintenance of the place. The TLB is shot but the Detroit engine runs well and the hydraulics are very strong. It came along to me in a trade when the former owner traded both the 11B, and this backhoe in on a new mid sized excavator. ![]() |
That's All Folks!
Codger
Posted: 16 Jan 2026 at 7:23am |
Going to pick up the freshly built/rebuilt 39MT starter this afternoon. Basically an older case with everything new inside. Wanting to get this old TLB out of where it's at and back to the shop for further evaluation; but the power shuttle seems to be worn out. Fine cold but as it warms, begins to slip and the tractor won't pull itself unless in low gear. Not much use pushing into a pile this way at all......
That's All Folks!
Codger
Posted: 17 Jan 2026 at 6:12am |
What a circus. Rebuilder did a nice job building up a new starter but installed 24VDC field coils instead of 12VDC and won't work in the application. Too late in the day when I arrived to correct so will be addressed the first of the week. Forecast is very cold for the next few days so no real loss of time.
Edited by Codger - 17 Jan 2026 at 6:12am |
That's All Folks!
Les Kerf
Posted: 17 Jan 2026 at 7:57am |
Bummer :-(
Codger
Thanks(1)
Posted: 17 Jan 2026 at 8:21am |
Yep, we were talking about the 11B, and my large DD powered air compressor (which are both 24VDC) along with this tractor and the conversation got convoluted. All starters use the same SAE #3 mount, are CW rotation, but use different drives to intermesh in the ring gears. All straightened out now so will be corrected Monday. Tuesday is supposed to reach back into the 30's so will hopefully install then.
That's All Folks!
Codger
Posted: 19 Jan 2026 at 9:37am |
Got a call and starter is rebuit to 12VDC but it's one degree here now and going to remain cold today so probably not even going out of the house.....
That's All Folks!
Les Kerf
Posted: 19 Jan 2026 at 12:00pm |
Good plan!
Codger
Posted: 23 Jan 2026 at 3:34pm |
Warmed a bit yesterday so picked up the starter and installed. Engine fired readily and settled into an anything but quiet, smooth idle. I need to top off the shuttle reservoir as it was found too low to move the tractor so further delay..... Tractor has a single speed B-W power shift transmission in front of a B-W T-18 series four speed manual transmission minus the reverse gears on both the main, and counter shafts. It works well when cold, (and obviously has oil) but needs a rebuild.
That's All Folks!
Codger
Posted: 23 Jan 2026 at 3:40pm |
This is the same transmision that is installed:
That's All Folks!
Codger
Thanks(1)
Posted: 25 Jan 2026 at 11:49am |
Couldn't work with that new alternator for the air compressor. Input shaft is shorter than original and could not install original dual belt drive sheave onto the replacement. Also discovered, (though don't remember doing it) the lower swing mount being ground back 1/2" to allow proper placement for belt alignment. Been several years since this was done.
Having several of these 10SI series alternators in the shop of unknown dispostion, I tore the orginal, and an unknown apart. After metering the rotor slip rings, and stator of the original alternator, diodes, and diode trio of the donor alternator, I reassembled the front of the original onto the rear of the donor and reinstalled onto the compressor. It immediately started charging but at too high of voltage. Output was about 17.3VDC output and pegging the 30A ammeter. When it warms a bit, I'll pull it back apart and swap in a new regulator as I suspect this is why the donor was taken out of service originally. It was a "Transpo" brand and 12VDC labled right on the regulator itself.
Edited by Codger - 25 Jan 2026 at 11:51am |
That's All Folks!
Codger
Thanks(1)
Posted: 29 Jan 2026 at 10:56pm |
Danged weather has slowed my alternator innards shipment so don't have them yet.
Found a new set of pole shoes for the 30MT starter, and purchased a new solenoid along with brushes/bushings. I rebuilt the motor part as the field coils were good, but have yet to receive the weatherproofing rubber boot so another project at a standstill.
Should be going after this HD-5 within the next couple of weeks. Widow has located the ignition key, and operator station floor panel so tractor is relatively complete. Will probably be the first load hauled on my new to me Talbert detach trailer. Following Coke's advice, I have located some 2.50 thick steel plate in a local scrapyard to bolt onto the back of this tractor. Certainly can't hurt anything to be on there. Haven't used my track torch in a spell so it will see some use for fitment. My Hougen mag drill will push a 3.00" depth of cut annular cutter easy enough, so I'll need to acquire the appropriate size as all mine are 2.00" depth. |
That's All Folks!
Codger
Posted: 30 Jan 2026 at 10:34pm |
Well unannounced, the rubber boot showed up in the mail today so hopefully finish up that open task this weekend.
![]() Found and ordered a 3/4" x 3.0" depth of cut annular cutter and ordered it today. The bolt holes in the back of the machine appear to be 3/4" X 10tpi so this cutter should work well. They are painted over but I'll chase them with a bottoming tap before use. Postal service seems to have lost my alternator innards as they were in St. Louis on Wednesday and scheduled for delivery today, (Friday) then changed to Saturday. Tracking is now changed again with no update other that original shipment date. Ahhh, the joys of online shopping.
That's All Folks!
Codger
Thanks(1)
Posted: 31 Jan 2026 at 2:40pm |
Miraculously the alternator innards arrived in St. Louis this morning for the second time! Somebody there really has a consecration fettish for that package and just could not bear to not touch it again.
Assembled the 30MT starter this afternoon and it bench tests fine. I'll install it onto that Detroit engine later in the week for a functional run and keep it for a ready spare should it be needed.
That's All Folks!
Codger
Posted: 04 Feb 2026 at 2:28am |
Recieved innards yesterday afternoon. Promptly installed into three alternator back ends on air compressor and all are still overcharging and about 17.35VDC at a good little clip on the ammeter. This is the only 63A variant I have so I believe either the stator has partially shorted, or the rotor has. Regardless the charging value is too high and the entire alternator can be replaced for a little more than just a purchase of a stator, (example) alone.
Think what I'm going to do is order a new alternator, disassemble it, push the rotors from both alternators, and push the new rotor into the modified front case of the old alternator, then reassemble. This way it will be new guts in an old front case.
That's All Folks!
Codger
Posted: 09 Feb 2026 at 7:12am |
I did install that rebuilt MT30 starter onto the backhoe and it's a different animal now. Readily rolls the engine over and a small "snort" of ether and fired to life. May haul this back to the shop as weather is warming and I'd like to get some evaluation on the machine to either ascertain future use, or just part it. As mentioned earlier the shuttle trans is at end of service life and the balance of machine is questionable so really don't think I'd bear the expense for a rebuild. The engine and hydraulic systems are very strong and I do enough screwing around with fluid power I may repurpose the unit to a portable fluid power unit on running gear. Don't know yet....
That's All Folks!
Codger
Posted: 15 Feb 2026 at 8:28am |
Damn, that smoking starter video I posted was the wrong machine in work. Was for a New Holland bi directional tractor I'd worked on a couple of weeks back. Bad ring gear in that one along with a burned up starter motor. Don't have video of the backhoe starter motor.
Sorry for the confusion.
That's All Folks!
Codger
Posted: 18 Feb 2026 at 9:03pm |
Got to rooting in the junk at the shop and low and behold, I found the non working old 37A 10SI alternator originally from the backhoe that was corroded all to hell from being outside many years. Regardless, I busted it open, metered both the stator and rotor with both checking good. I then removed the rear case from the compressor alternator (which was overcharging) and installed the old stator into this rear case. I then reinstalled the back end onto the alternator, reconnected electrically and started the engine. At about 1200rpm the alternator picked up and here is the voltage output:
![]() It did start dropping the charge rate as the battery recharged but nowhere near the 17.7VDC I was seeing earlier. |
That's All Folks!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9262 |
Posted: 18 Feb 2026 at 9:54pm |
That's why you never throw anything away....
Codger
Posted: 19 Feb 2026 at 7:20am |
You should converse with my wife as she thinks I just harbor a bunch of "junk".
That's All Folks!
Les Kerf
Posted: 19 Feb 2026 at 5:54pm |
I tell my Wife that I am saving the environment by keeping all that 'junk' for re-purposing!
wjohn
Posted: 19 Feb 2026 at 6:39pm |
I hear you. I gave a scrapper $20 at an auction for a stack of Lincoln Ag seed plates that were tied with baling wire onto an old JD plate planter he bought. Fast forward a couple of years and figured out which soybean plates I need this spring... $85 each online for new. Went through the stack of plates, and sure enough, had what I needed plus an extra.
There is some sort of balance between having too much junk and not having parts when you are down and need them. I haven't found that balance yet... But it sounds like we were both lucky the last few days.
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1020 |
Posted: 19 Feb 2026 at 7:50pm |
Re "There is some sort of balance between having too much junk and not having parts when you are down and need them. I haven't found that balance yet... But it sounds like we were both lucky the last few days. "
But, if you accumulate with discresion, the more you have the more likely you have it when needed
Codger
Posted: 25 Feb 2026 at 10:39pm |
Got called away to look at a "Won't start chipper" for a local tree service. Turns out the starter on their machine powered by a 4-53 Detroit had burned up. Just happening to have the freshly rebuilt 30MT set up for a Detroit Diesel originally from the backhoe, I sold and installed it to the outfit to get them up and running. Big job they were involved with in a public park given the amount of wind gusts we've endured this past couple of weeks. I'll check this core over and possibly rebuild it for a ready spare.
That's All Folks!
Codger
Thanks(1)
Posted: 22 Mar 2026 at 8:04am |
Finally brought that old backhoe back to the shop yesterday. Starts easily and runs well, but remains very weak pulling itself. It did however drive right up onto the trailer easily. I'm actually thinking the torque converter may be the problem rather than the shuttle transmission, but have done no testing to prove. Ordered a new .5 - 5gpm hydraulic flow meter to go with a couple of others on hand, so will do some testing/proving before going much further with the machine. There are ways to test functions for operation and internal leakage using pressure and flow measurements as I really don't favor the "shotgun" approach to repairing things.
Upon starting the Detroit engine I did notice the ammeter not charging. Placing a meter upon the battery terminals proved it. The "one wire" alternator was new in the spring of 2021 and worked fine, and the machine really has sat unused since. I jumpered between the "BAT", and #2 terminal while the engine idled and it took right off recharging the battery. Obviously the low grade electronics in these knock off alternators don't retain residual magnetism very well as with a fresh excite, all is good. The replacement 39MT starter seems to work acceptably but doesn't spin the engine near as fast as the original 30MT starter did. The engine starts so easily this isn't a problem for me. The chipper I installed the original, and rebuilt starter from this machine on seems to be doing alright also. The task they were working with completed without any fanfare. Lawnmower prep season is upon me now heavily. I tend to work on quite a few Grasshopper, Scag, Kubota, (mowers and engines) every spring. Have two down for parts at this writing. Also need to get a couple chore tractors in for routine service though one has a leaking charge pump hose on it's transmission. This has a banjo fitting on one end so need to verify with dealer what it actually is so it doesn't set around for a long time awaiting parts. Had the block machined, and cam bearings fitting to my Kubota block so can now put it back together. No cam bearings in these small diesels and when the front crankshaft bearing spun in it's bore blocking oil flow passage, the rotating innards were destroyed. I had the block bored in the cam journals and custom bearings fitted so a new cam will go back in. Hope to slip this one back together later this, or next week get it running and sell the mower as surplus to my needs. |
That's All Folks!
Codger
Posted: 24 Mar 2026 at 10:11pm |
Received flowmeter so now have test equipment for low, to medium flow applications. Found a test procedure online I think is correct for the transmission also. Research online also shows many forklifts used this same transmission which I found as a surprise as AC was included in there as well as Clark, Hyster, Towmotor, etc.
That's All Folks!
Page <123> |
