190XT diesel lowest RPM
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: 190XT diesel lowest RPM
    Posted: 1 hour 39 minutes ago at 4:07pm
Hey y'all.
I know the addage "throttle down gear up" and quite a lot of my work is low power.
What's the lowest working and long term idling these engines should do?
I don't want to starve the motor of oil or cause stress on it when I don't need to. But I do not need all 100hp and 2200rpm for things like moving equipment around the yard or making an empty trailer.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 22 minutes ago at 4:24pm
Interesting question.  How often do you give it a decent workout?  I don't own a 190XT, but I've raked hay for hours on end at 1000 rpm or so with many tractors.  Just enough speed to where it will hold a steady speed.  But then those tractors get worked or revved at other times.
Does the temp come up on these tasks?  If so, I'd think you're ultimately OK.  Sitting idling for long times can "wash" the cylinders which isn't good of course.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 5 minutes ago at 4:41pm
For a 190 diesel i would want to go 1500-1600 in the field. Just putting around the yard 1100+. Even when I sit and load a manure spreader quick I like to run 700-800. Other wise next you will be posting about black running down your exhaust.
