190XT / D17
Hurricane Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurricane Allis Quote  Post ReplyReply Direct Link To This Post Topic: 190XT / D17
    Posted: 03 Oct 2012 at 11:55am
Can anyone tell me if a 190XT Gas engine would anyway shape or form fit into a D17?  How much horsepower do you think a D17 running gear hold up to?  There is a couple of Oliver 88's in our area with 1850 gas engines ruling the roost in the 4500lb to 7500lb open classes.  I would like to see a D17 on steriods get their attention:)  Thanks for any info!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 1:41pm
I assume you have 1959 production rules?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 1:44pm
There is a WD45 running a Turbo 301 pushing over 100 hp locally that has had no issues with the rear end. It did shear an axle though.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurricane Allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 9:33pm
Is there alot of difference between the D19 gas engine and the 190xt 301 gas engine?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 10:59pm
Huge difference between the 262 gas and a 301. We've covered this topic before and for the money I'd get a combine adapter and drop in a Chevy 292 as there's lots of mods available and they make tons of power.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurricane Allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2012 at 7:23am
Now you 're getting my attention!  It is going to have to be pretty beefy as I know these Olivers are starting out with a 90+hp gas engine out of an 1850 and then port/polishing the head, one is even stroked with defferent cam, so I know probably well into the mid 100hp range anyway.  I'm know stranger to making horsepower on the GM Big Block V8 side but the buzzn half dozen I 'm just starting to get my feet wet!..
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 5:34am
A chevy 292 is probably 140-150 h.p. Stock. Only problem I see is rpm's the 292 makes that kind of power at a lot higher rpms that the oliver 1850 engines your talking about.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 2:00pm
Cam should take care of the rpm/hp issue with the 292. Just need a grind to help with low end torque. I'd just build a stout 226 or 262 to stay all orange.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 2:15pm
A 292 chevy is still disadvantaged against the cubic inches you   can get out of the oliver.then theres the red diamond 500 inch for the ih. A stroked 426 converted to alky would be the engine that got the rules changed.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 3:27pm
Allis had that tractor from the factory, they called it a 180,  Ya I know its a 265 but wondering if a 180 chasis plus a 301 and  d17 sheetmetal would be a easier/better route?
I agree about the cubes if those Olivers are as big as the outlaw Olivers around these parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 4:45pm
I have gave some serious thoughts on upsetting the rules some.the 426 should or since combines had v8 chevies a person could get around the no v8 clause by milling one bank off a a 632in bbc to make a stought little four banger or just put the big oliver wakeshau in the allis since they were purchased and merged.
Edited by mlpankey - 08 Oct 2012 at 4:51pm
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 4:54pm
butch...the 180 diesels are 301 so it will definatly bolt up a gasser
