190 Bareback ? |
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Topic: 190 Bareback ?Posted: 10 Jan 2013 at 2:06pm |
My friend that pulls a 190xt allis wants to find the parts to make his a Bareback. No pto,3 point, it is a modified class with aluminum frame rails. Wish I had a picture to post.
DougG
Posted: 10 Jan 2013 at 2:24pm |
Its easy to do, pull off the rear 3 pt housing, cap the 3 pt hyd lines, pull the pto shaft outa the back, put a steel or aluminum plate on the back where the housing was and you got it, could foam the rear end so you dont need so much oil, but if you dont need to worry bout the weight loss dont worry bout the foaming
Edited by DougG - 10 Jan 2013 at 2:27pm |
Posted: 10 Jan 2013 at 6:10pm |
You'll need to stick a short dummy shaft in where the PTO was to keep the hydraulic and trans oil where they belong. |
2wise4agm
Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
Posted: 10 Jan 2013 at 6:37pm |
I would like to do the same to mine this winter if I can get all my home improvements done. It seems simple enough.
DougG
Posted: 11 Jan 2013 at 5:45am |
It's very simple to do,
Edited by DougG - 11 Jan 2013 at 5:46am |
