185 joystick loader control
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Topic: 185 joystick loader control
    Posted: 16 Aug 2018 at 10:15am
I was thinking about putting a joystick on my 185 to run my 500 loader . It would be nice to free up the remotes.
Has anyone done this?
I was curious where to plumb in for supply and return oil ect.
Thanks
185 turbocharged w/ 500 loader , WD
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:45pm
My 185 loader has its own valve its piped into the hydraulic valve body don't know
exactly how, was like that when I bought it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 9:03pm
Ok I wonder if a guy could tee into the line going from the hyd pump outlet to the remote valves and go to the joystick or would you have to put the joystick valve in series?
Where would be the best place to put the return oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 9:24pm
Somewhere here there is a sketch of how to do it. Probably can find it with a search. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 9:53pm
Ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 10:44pm
Originally posted by 185turbo 185turbo wrote:
Ok thanks
Turbo, pm me your cell and I can text you the pics. Tracy
ezlle71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 3:53pm
There is a union on the main hydraulic feed to the remote valve stack, run 5/8 hose from the feed to your joystick. Then 5/8 hose from power beyond on the joystick back to the feed line. Then from return port on joystick go back to sump on tractor. Make sure joystick is open center with power beyond. I just did the same thing on my 190XT earlier this summer. I love having the remotes freed up.
190XT, 185, D15 SII, 7040 is living again, 7010 retired for parts.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 8:28pm
Here is a sketch I posted for a 190. The 185 should be similar.
chalmera View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 8:44pm
Which stick are you planning on using?  I have a 400 series loader, has its own pump, but the spool valve is shot.  Looking at my options.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 4:34pm
I am in a similar situation to chalmera.
I have a 500 series loader.
Brand, model and price of replacement?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 7:10pm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 9:36pm
70349914  is the part number for the valves.
AGCO Allis Parts Books
A-C FARM LOADERS - ALL MODELS
HYDRAULICS - VALVE
Page 140 item 12
Edited by Clay - 20 Aug 2018 at 9:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 11:13pm
I think you need open center and power beyond, IIRR. Tracy
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 11:21pm
How does a Prince RD522CCAA5A4B1 compare to a Cross BA2A1XAG3EA0?
The Cross is 30GPM while the Prince is 25GPM.
The pump on my loader is an 11GPM (26009-LAA  1.48C.I.D.)
I
Prince RD522CCAA5A4B1 Directional Control Valve, Two Spool, 4 Ways, 3 Positions, Tandem Center, Cast Iron, 3000 psi, Lever Handle, 25 gpm, In/Out: 3/4" NPTF, Work 1/2" NPTF
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 12:32pm
Finally getting around to putting on joystick I have a cross 2 spool valve used with no numbers that seem to mean anything.
I have a question as to what port to hook where on the valve
I have a block on the lh side of valve with p and T pressure and tank and then another fitting on the rh side.
Does the T port go to the transmission sump or the rear remotes there isn’t a port labeled pb for power beyond
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 2:22pm
You need the power beyond sleeve that goes in the T or return port. That goes to the inlet of the next valve. There should be another return port that is plugged. That is where the new return goes.
Your valve should look like there.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 3:41pm
Here is a post I did on adding joystick to 190XT.  I think they are similar in case any of these details helps.  Sounds like you are close to being done though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 5:22pm
I
The two are pretty much the same valve. I actually used the Prince SV valve on my 190XT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 6:47pm
Found the port I needed thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2022 at 5:57am
On my 180 I did not T into system, next to the battery box is a coupling connection where I split that sent the incoming fluid to the joystick, then a line from the power beyond port on joystick to the split connection on to remaining three point and remotes function. Simple and quick install, easy to remove with no special fittings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2022 at 10:45pm
Got the joystick hooked up and plumbed in , pretty slick
