170-175 dual pto
Josh N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Topic: 170-175 dual pto
    Posted: 27 Sep 2026 at 1:00pm
Is it possible to take a dual speed pto housing off the rear end housing of 185 and bolt it on the back of a 170-175 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 4:13pm
Yes. But you'll not have a 540/1000 RPM PTO. You'll have a 270/540 PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 7:56pm
Ok.   Can you bolt a
185 transmission housing to a 170-175 torque tube?    I would think the transmission input shaft would be different because of the different power directors?   Now that I think about it you would have to change the gearing up in bottom of torque tube like you have to when putting a dual pto on a 190
Edited by Josh N - 27 Sep 2026 at 7:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 7:53am
Yes. The Allis 540/1000 PTO system all started up front with the PTO being 1000 RPM and then getting reduced to 540 at the rear gear train. No way to alter that on D-19's on down. The mighty One-Ninety was their first tractor to have PTO design change which involved with two possible speeds and a hydraulic clutch. They didn't incorporate true "independent" power at that time and probably should have.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 9:33am
AC 170-175 Shuttle Had 540-1000 pto
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 9:59am
Yes, they did. And I remember them being a very odd speed, like 800 RPM on the 540 side ?? something not normal anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 6:59pm
I just now got my official A-C service manual out and much to my surprise a 170 or 175 that has dual 540/1000 RPM PTO with a "shuttle clutch", does indeed have quite normal PTO speeds of 660 RPM at 2,000 engine RPM on the 540 side and 1200 RPM on the 1,000 RPM side. I was confusing myself with D-14's and D-15's equipped with a shuttle clutch.
Edited by DrAllis - 29 Sep 2026 at 10:23am
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 8:35pm
I just now got my official A-C service manual out and much to my surprise a 170 or 175 that has dual 540/1000 RPM PTO with a "shuttle clutch", does indeed have quite normal PTO speeds of 660 RPM at 2,000 engine RPM on the 540 inside and 1200 RPM on the 1,000 RPM side. I was confusing myself with D-14's and D-15's equipped with a shuttle clutch.
That is great news! I remembered reading some posts on here about the weird PTO speeds, so I hesitated on tearing into my shuttle clutch 170 yet in favor of working on another one w/o shuttle... But maybe that shuttle clutch tractor is the ticket now, especially with the loader on it. Thanks for looking that up and sharing it.
