1 wire alternator
kyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyman Quote  Post ReplyReply Direct Link To This Post Topic: 1 wire alternator
    Posted: 26 Jun 2026 at 7:40pm
i have a d15 series 2 gas. i am looking for a 1 wire alternator to fit it. any know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 8:20pm
nothing is going to be a plug and play FIT... Your going to have to modify the mounting braket to get the pulley / belt to align and a tightening bracket... The most common  "1 wire" is the old DELCO 10SI that has been modified internal to work on 1 wire... here are a couple versions on AMAZON..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 8:40pm
here are some dimensions if you want to see how it will fit...
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 9:02pm
Get your generator rebuilt and you will be good to go. No rewiring or fabrication needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 9:40pm
thanks
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 9:49pm
On ebay there is a seller that has the bracket you need to mount an alternator.Alternator is the way to go much better than a generator and alot less hassle and cost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 10:00pm
and....... generator needs a Regulator..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2026 at 6:27am
And the regulator can cost more than an alternator and don't work a lot of times too
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2026 at 6:35am
nurther option..
CS-120 (?) version Smaller physically,lots of amps
All 4 of my D-14s had them
Not '1-wire', had idiot light to tell if fan belt broke or not charging.
All scrapyard finds for $10 or less.
