Zenith over flow
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: Zenith over flow
    Posted: 20 hours 11 minutes ago at 1:39pm
Allis C. I’ve tried it all. Carb has been cleaned with Berryman cleaner. The body also soaked in evaporust. Added inline fuel filter. Float height is good and floats do not hang up on side wall. New gasket under float needle seat body. I even removed the wire clip between the float and float needle. Tried different needles.
Only thing left is buy several needles and seats in hopes I get a good match.
I’ve read the aftermarket carbs have poor performance. Is a Marvel carb an option?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 26 minutes ago at 2:24pm
does the float leak?    boil it to see if it bubbles  or hisses
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 16 minutes ago at 2:34pm
No I checked that also. If I blow into an empty carb bowl it holds holding upside down. As soon as it overflows I disconnect fuel line from carb and attach a hose and blow it appears to hold but under gravity feed it overflows as soon as the bowl fills up with fuel valve open. I measured the original needle to be a few thousands larger than the new needle thinking it gets kicked to side of dead center into seat hole. Sad because this tractor has been completely taken apart and overhauled from lower drive to engine.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 9 minutes ago at 3:41pm
Originally posted by 3rd generation 3rd generation wrote:
... under gravity feed it overflows as soon as the bowl fills up with fuel valve open...
Methinks the float doesn't float enough Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 19 minutes ago at 4:31pm
if you have tried several needles and they all leak, then i would lower the float like Les said..
Skip, W.Pa View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Skip, W.Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 51 minutes ago at 7:59pm
I have had  problems with the main jet discharge tube gasket leaking. Some were not tight enough and leaked at the round gasket under shoulder. Some the gasket dried out from sitting extended period with no fuel in carburetor. Makes you think it is a needle seat / float issue. When it leaks gas will wick it's way up past gasket and drip out the bottom of carburetor when tractor sits for period of time. Something to look at when you take carb apart.
Post Options Post Options   Thanks (1) Thanks(1)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 20 minutes ago at 9:30pm
what skip said   set just the bowl level with the nozzle in and carfully and slowly fill it with gas and see if their is leaks bottom of those bowls can crack if they have had water in it and froze , but the nozzleis probley leaking at that gasket,  0if the float is good  and the seat is polished
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 28 minutes ago at 7:22am
What needle came with the latest carb kit? If it has a soft/urethane tip, they typically seal well no matter what (as long as the float's not rubbing and set correctly). But if it's a solid brass needle (which I think the original would have had) they are often difficult to get to seal fully. 'Proper' practice for a solid brass needle & seat is to place the needle in the seat and very lightly tap it into the seat with a small hammer, turning it slowly between taps, to get a full face seal. Though admittedly the machining tolerances these days are 'usually' good enough that it's seldom necessary. But if having trouble, that's where I'd start.
Also make sure the faces between both halves of the carb bowl are uber-clean and flat, with the proper gasket on there. An air leak around there can cause some funky leaking behavior that doesn't always seem to make sense or be traceable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 32 minutes ago at 8:18am
Good point Smile
