Working on 180 wiring. |
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1284 |
![]() ![]() ![]() ![]() ![]() Posted: 17 hours 39 minutes ago at 8:37pm |
The switch has 3 positions.
Low roadway High roadway Full field mode On the rear lights. It has the rear work light and the fender warning light. Which switch position should the rear work light turn red? Is the fender light supposed to flash or be on steady? And which switch position should that be ? |
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1937 |
Low and high road should have your tail light and flashers. Field would have your work lights.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5031 |
Just to expand a little, both yellow lights are flashers. Flashers and tail light should go off when you are in field mode (all lights would be "white" in the field). Dad's 180 had two yellow flashers (one on each fender) and one rear red light on the left fender.
