Woods Belly Mower ?'s
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: Woods Belly Mower ?'s
    Posted: 25 Oct 2017 at 10:37pm
Will the spindles, housings, and pulleys interchange between a L306CA mower and L59CA mower? Will anything else interchange as well? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 6:43am
The housings will interchange. The  spindles will as long as they come from a L prefix mower, difference being left hand threads for the blade bolts.  By the way the bearings for a Woods belly mower spindle is the same set number as used for the front wheel outer bearing  of any 60s 70s Chevy car with drum brakes and a darn sight cheaper at any car parts place than from Woods.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 7:43am
I had a bearing go out on a spindle on my Woods L-306 many years ago.  By the time I priced all the parts to fix it (bearings, cones, seals, etc.) it was only a few dollars more to buy a whole new spindle.  I did the latter.  It was much easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 8:33am
I bought whole spindles from our local tractor dealer that were for a New Holland mower. They were less expensive and as far as I could tell were the same spindles.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 11:42am
I don't need spindles, I just wanted to know if the parts would interchange. And yes, Woods parts are expensive but what isn't. I have a L59 deck already and  I am going to pick up a L306 deck today. If the parts interchange, great! Thanks, Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 3:43pm
Hubert, got any numbers for us??  I don't need one right now, but........ Did you know that Murphy and I are best friends,,,,,,I think....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 3:56pm
Been several years and I didn't write the numbers down but I will see if I can find that invoice.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 5:44pm
The blade attaching hardware is different for the L59 and L306 I have.  In the manual too.  Apparently, there is a clutch design in the L306 to permit slipping that is different in the L59.  I know, I just ordered all new attaching hardware from Woods.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
This page was generated in 0.219 seconds.
