Will modern deeper oil pan clear on 220
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Topic: Will modern deeper oil pan clear on 220
    Posted: 10 hours 56 minutes ago at 11:44am
   Will a deeper oil pan off a 7060 clear the wish bone front end on a 220??
   Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 25 minutes ago at 1:15pm
I think so. All 210's and later model 220's had the crankshaft driven oil pump on them from the factory and as far as I know, no changes to the front axle.  Many old 220's that failed the camshaft driven (original) oil pump were retrofitted with a new style crankshaft driven oil pump and deeper pan as the fix.  EDIT:   A 210/220 crankshaft driven oil pump is p/n 74028052  The crankshaft driven oil pump for a 7030 is also 74028052.
Edited by DrAllis - 6 hours 51 minutes ago at 3:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 minutes ago at 10:38pm
My 70 model 220 had 3000 ish hrs when i got it. It has a block with no serial # on the plateand has crank driven pump. I assume it was one that failed and was replaced with later stuff. Can't speak to the oil pan issue other than it has one that fits. At 5 1/2 gal it is full on stick and follows manual capacity. That's 1 qt more that my 8000's with the bypass filter and larger oil filters. That don't make sense to me.
