What's the most fun you ever had?
Don(MI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: What's the most fun you ever had?
    Posted: 13 Oct 2026 at 8:43am
I'm talking about most fun to your own definition with old Allis tractors!
Could be a barn find? Unburying it after years of storage?
Could be an old tractor starting up from a 30 year nap.
Could be taking a salvage tractor to fully functional condition?
Could be farming the back 40 acres cutting hay?
Could be a tractor parade with your family?
What was the best memory to you??
Galatians 5:22-24
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 9:06am
I was new to tractors in the early 90s. I bought a c with a b front axle. It came with a sickle bar. I bought it to mow my lot that was over grown with weeds. I started mowing with it and was making rounded turns at the corners. One time when I was at the end of the row, I hit the right brake while turning and it made a perfect 90 degree turn.
It was amazing to see how the bar swept around to make the corner.
'41 Allis B
'49 Farmall Cub
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 9:22am
Some memories of sounds you never forget.
B on a buzz saw. The governor kicking in halfway through a
good sized log
D15 on a feed grinder ( still do this occasionally)
D19 gas on a silage blower pushing it up 90ft.
E gleaner engine with a 30kw generator attached
WD45 going a 1/4 mile with a 4row cultivator and listening to
the brake pedal bang on the footrest turning on the end
7000 plowing in the fall darkness. You could see the stadium lights
and hear the engine like you were standing next to it.
7040 with the discbine makes a sweet sound with the 2 steady tones.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 10:32am
Most fun was plowing with a CA in the 1960s and 70s.  Second discing with an 8 foot dunham lehr disc with a heavy drag.  Third planting corn with a two row.  I'm not sure grandpa was happy with my performance, he only let me do it once (I was about 12).  I also spread orchard grass seed with a broadcast spreader.  It fit the CA, but I don't think it belonged to grandpa, I think he borrowed it.  I'm pretty sure I cultivated a garden at least once, but I can't really remember clearly.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 10:56am
Thinking about this makes me wonder about my sanity. Most of my best memories are running through the night and getting done as the sun is coming up, usually running a baler. Did it twice this year, once on the seriesIII and once on the 7030. When I had my 7060 years ago I liked to plow at night, less distractions to what you are doing. Nothing quite like watching the sun come up on a completed job.
In the last three years we have had at least three times that we have finished baling with the stackers right behind us and the rain hitting less than half an hour later.
I bought the 7030 and the D14 this year at auction for low prices on both, that was fun too. And then finding that they were each in better shape than expected was a fun experience.
Lots of what I would consider fun experiences, but I can't think of one that sticks out as the most fun.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 11:23am
The time that Dad, my son , and I all won first place trophies at the same tractor pull. Treyson won the 2,500 class on a 1948 B. Dad won the 3,500 class on a 1937 WC, and I won two classes: 3,000 class on a 1950 C and the 4,000 class on a 1938 WC. Actually lots of "best times" playing tractors with Dad & Treyson, with more to come! At 92 years old Dad is still an active participant and we'll all be pulling again in a couple weeks!!
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 3:39pm
My first time driving a tractor, my uncles F20, I was only 7 years old. It was summer in the late 40's and it was time to bring loose hay into the barm for winter storage.  This was prior to using a Bayler.  Picture a tractor a hay wagon and a hay loader attached to the rear of the wagon. It was a long train of implements.  My uncle, and my grandfather were on the wagon. One of them would get off the wagon, put the tractor in first gear, let out the clutch. My job was to stay on the row of windrowed hay.  That was a pretty impresive job for a 7 year old.  The fact that they trusted me to do a good job still amazes me.  Its a memory I will take to my grave
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 9:23pm
One memory that comes mind was drivingng Dad's 9N Ford pulling hay up into hay mow on the old hay forks - I was 5 or 6 years old. Another recent memory is plowing with my D-21 and 6 X 16 9000 series plow. Our plow day this year was cancelled because of % plus inches of rain 2 days prior to the day.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 4:09am
The most fun? Wow, that's hard to pin down! So many great times on Orange tractors, (and Red). I'm going with riding on the toolbox of the WD with Grandpa at the wheel. Hard to believe that tractor was less than 20 years old then.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 5:42am
Most fun I ever had was using my D19 right after I got done with a full on rebuild/restoration on it. Very first Allis I ever owned, and after I rebuilt it, it pretty well changed my whole perspective of Allis chalmers for the better. It does still jump out of 3rd gear. Hopefully sometime before I expire, I can have that fixed.
Another favorite thing to do is roto baling. Problem is, is that there isn't much use for that around here anymore.
Something that I am looking forward to doing, is plowing. Hoping to sometime soon, get my 7580 fixed, and hook it up to my six bottom semi-mounted plow, and go have some fun.
Darrel
This page was generated in 0.116 seconds.
