What hardener are you using in Agco paint?
Jack C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack C Quote  Post ReplyReply Direct Link To This Post Topic: What hardener are you using in Agco paint?
    Posted: 01 Jan 2019 at 8:40pm
If anyone has painted your A-C’s did you use the OEM paint. I’m learning Valspar is the paint mfg. And it’s not a true acrylic enamel, rather a “ modified synthetic with acrylics added. (Agco spec sheet) But what I’m actually asking if you used the Agco paint, what brand/product description hardener did you use? Did you use Agco’s Renew 3001 or ??? For example PPG DU 5 . Thanks
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 5:21am
I have used the Renew 3001 that is recommended for it.  Only place I could find it was a CaseIH dealer.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 6:05am
I have always used valspar renew and had good luck. I buy it at the John Deere dealer.
badjeep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote badjeep Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 2:08pm
Ive used everything from el cheapo tractor Supply hardner to left over urethane hardner and have had no issues ever with mixing them with the Agco paint, have always been happy with the results
In the shed- 7020,7060, L2 X (2), CII, WD X (2), 200, 210, 611H, 440, Fiat Allis 345B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 4:29pm
Using Tisco paint and hardener. Not sure if these are the same as the Valspar?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 4:49pm
Does the AGCO paint hold up as good as Dupont or Nason?
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 5:33pm
valspar hardner works good with any imp' paint' use enamel reducer for thinner. all that mineral spirits' thinner is junk; it has oil in it 'no good an takes to long to dry.
This page was generated in 0.056 seconds.
