What gleaners came with the 301?
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Topic: What gleaners came with the 301?
    Posted: 09 Aug 2012 at 6:43am
Just wondering what gleaners had the 301 diesel in them?
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 6:46am
Off the top of my head, the M series and some L series had the 301 in them.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 6:53am
F and G too.
Edited by Lonn - 09 Aug 2012 at 6:54am
Wink
I am a Russian Bot
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 7:23am
Early F2's had a 301 non-turbo also.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 7:55am
M 2 and some L 2 without hydro, some Gs
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 8:04am
 Had a 1976  M with a 301, it was awsome, 2900 series, 130HP. It was a hydro too...
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 9:30am
F, EARLY F2 UP TO 1977 -2800 -301ci, MOST F DIESEL WERE CAM DRIVEN OIL PUMPS, F2'S WERE CRANK - WE HAVE FOUND A FEW BOTH WAYS AS AN EXCEPTION IN THE 76-77 YEARS,  G DIESELS 2900 (190xt), L,M 1972-73 2900 WITH SIMMS INLINE - INDUSTIRAL WITH LARGE OIL COOLERS MARK II   L,M  STD ENG IN L2 AND M2'S WERE THE  DM EQUIPPED ROOSA 6.49 T (7010-8010 TRACTORS) AND A FEW OF THE M3/L3'S HAD THE 6.49I (7020).
Most all the blocks we have found with crank driven oil pumps were drilled for piston cooling whether THE BEARINGS WERE SLOTTED OR NOT.  One should not use piston cooling with the cam driven oil pump as there will be a very low oil pressure at idle.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 9:35am
Interesting info, tbran. What's the deal on the 301's with the simms in-line. Were they better, worse, no diff? Thanks, Darrel
