WF questions
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: WF questions
    Posted: 13 Feb 2012 at 6:41pm
bought a WF to restore, started on it today, looks like i need to replace head gasket as its seeping, anything i need to know before i take head off??  also whats behind the steel plate on right hand side of block, looks like maybe 6 bolts holding it on, is there a gasket under neath of it?
Cowboy UP
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:21pm
square plate covers the push rods, there is a gasket I replaced mine last year as it leaked a little bit down the side of the engine. gasket is still available from tisco and some vendors on this site, around 12 bucks. put a thin layer of high-tack gasket sealer on it to keep it from leaking. I would replace the oil filter base gasket too while you have it off
Edited by Bill_MN - 13 Feb 2012 at 7:23pm
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 10:30pm
got a set of perfect steel wheels that would look nice on the old girl for 350.00 im in southern mn 507-339-0175
WCTech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCTech Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 10:57pm
BLee - The WF is a good model to work with, considering it is based off the WC which was such a high production number tractor for Allis. 1st thing about taking the head off, you will want the following gaskets on hand. Head gasket, water manifold gasket, radiator hoses, water pump gasket, manifold gasket, a BIG hammer (not your hand) and patience. They can some times be vey stubborn and may require slight "prying" to get it seperated from the block. When it comes to procureing these items, AGCO still has all of them available. If you aren't lucky with having a dealer near by you can contact Norm Meinert in Davis, IL he can you all that and then some. When it comes to putting it all back together becareful as to not tighten the valve cover too tight. It is very easy to tighten it and create a "valley" around the bolts. This will cause the bottom to work its way out through time and creating a leak in the future. Usually about the time you spend 2 years working on the tractor then get it all painted up. LOL Also when removing the oil filter base also remember the "not too tight" theory when tightening it down. Those oil filter bases are made from what I call "pot metal" and if you tighten them too much they also have a tenendecy to crack not allowing a good seal. Hopefully this is the info you are looking for, or maybe more then you wanted. Hope this comes in handy. Don't trust me though I am only 29 and have only been working on allis's since I was 13, when I received my 1939 WC for my 13th birthday. And it has been an awesome ride since then. Even when it took out the garage door! LONG STORY!!!! lol
Matt "Crash" Pehl
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 5:25am
Use a BIG hammer to loosen a head on a block  ??
If it didn't have any hairline cracks before you started, it probably will have before you are finished.
How about a smaller hammer and a block of wood?
Gary
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 7:11am
head gasket from napa is 28.00 head set is 36.00
ROGER
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCTech Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 10:23pm
Gary - I meant to say a dead blow hammer not a steel one but I see I left that out. You are correct, a gentle "tap" here and there helps, but no beating it like a rented mule to get it apart. Thanks for clarifying. Matt
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 10:59pm
99% chance it will have a hair-line crack between the cylinders but that is ok i ues COPPER COAT to seal head gaskets and neaver have any trouble i had to grind the valves on my WF it had been sitting for 20 yrs. but runs great now it is a fun tractor to drive mine is a 1945 model. have fun. Tom
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
