Welding cheater
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Welding cheater
    Posted: 9 hours 6 minutes ago at 5:16am
What do you with aging eyes do for a cheater in an auto darkening helmet?
I use my glasses but still can’t see as well as I like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 46 minutes ago at 5:36am
Have tried the Cheater inside lens sets, did not like as not close enough, still using my 1.5 cheaters under the hood, did lighten the auto dark feature a step at a time until could see without injury.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 29 minutes ago at 7:53am
yes... if youi lightne up the setting on the "DARK" it helps a bunch.. Dont go below the "8" mark if you do much welding... Flash will eventually get to your eyes and make them sore... Many people use the 11-12 settings... Try the 9 and see if that helps. ....... and i keep my glasses on (bifocals) for the close up work.
Edited by steve(ill) - 6 hours 28 minutes ago at 7:54am
Jgranat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 16 minutes ago at 9:06am
I find I weld better without my bifocals because I never can get the correct angle to make my vision clear while wearing them.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 10 minutes ago at 9:12am
I never liked the "cheaters" as the best focus area was never right for me.  I use a pair of drugstore reading glasses of the right magnification for my eyes under the helmet.  Much more satisfactory for me.  If I'm doing TIG welding I use reading glasses with one more power of magnification.  Works for me.
