Wd45 stalls out under stress
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 11:40am
Champions do better as a fishing sinker than in your engine. I like AC Delco Autolite or NGK, or Motorcraft in a Ford. Only problem is at some point in time Champion makes plugs for everybody. Just depends on who needs what and what they're tooled up to make.
That said, you've got either a condenser or coil breaking down. Either upgrade it to a Pertronix and Flame Thrower coil or use Standard Blue Streak from our buddy Steve in NJ.
Edited by Brian Jasper co. Ia - 03 Apr 2017 at 11:43am
Mountain goat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 4:16pm
Well guy's it wasn't the champion plugs I guess I try coil then points then cap rotor wires condenser
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 5:13pm
Do a compression test, you may have a weak engine. Trev.
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 7:30pm
Do you have good fuel flow to your carb does it stall or run crappy going down the hill ?
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 9:13pm
I think when you get to the wires you'll have found your problem.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 6:59am
another little tidbit......  check the cap and rotor... If the rotor doesn't make really good contact you will have a weak or no spark condition. I have one rotor that's a cheapo and nearly every time I go start the tractor, i have to bend it out to touch the cap. otherwise it won't start or runs poorly. I bought it that way, cheap...
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 7:12am
Have you checked the timing yet? I was going to suggest it before, but someone else already had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 4:42pm
I have adjusted the timing 4 times but just by ear I just try to get the fastest and the smoothest and then retard it a bit. I don't know how to do it with the timing light.I noticed it has a slight seep of coolant coming out the head gasket on the sparkplug side of the motor.son of a biscuit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 8:29pm
They seems to be how everyone on here says to time it by year, unless you're using a timing light. Is it seeping coolant or oil? The pushrod oil galleys run very close to the edge of the head on the spark plug side and tend to seep oil.
Take a look here if you what to see the head off.
And here
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 10:18am
...when mine was seeping like that,I grabbed the tq wrench and they all moved....dried it up.Must reset valve lash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 12:16pm
It was coolant green n clean but no coolant in the cylinders looks like there might be a bit of oil in the 2 cylinders that r fouling out. Does this sound like it could be the root of the problem. Seeping ecsess oil into cylinders and fouling plugs
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 2:43pm
Have you checked the coil?????
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 6:38pm
Is there a way to test the coil. I checked it to see if it was hot n it wasn't
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 8:14pm
Plug in the wire that goes from the top of the coil to the distributor cap. Support the other end 3/8" from the ground terminal. Connect battery voltage positive to the positive terminal. Connect the battery negative to the negative terminal temporarily. Every time you break that connection there would be a spark across that 3/8" air space. Without a condenser it will be yellow. With the proper condenser across the connection you break the spark should be blue. Be careful to not contact the high voltage parts with your body, it will HURT big time. There can be enough voltage on the circuit you break to shock too so be careful use insulation between you and that wire.
Gerald J.
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 8:35pm
I'll put my 2 cents in also. I had a WD and it had the similar problem. I changed the spark plug wires and problem solve. It backfired when under load also. Also different spark plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 9:34am
Well guys I got sick of messing around so I went all out on the electrical. New points cap rotor coil. Plug wires condenser. Problem fixed. Don't know what it was. don't matter she runs great   paid 1800 for it n stuck 100 into it not bad for a wd45 with a front bucket loader. Just wanted to say THANK YOU GUYS FOR ALL THE HELP. MOUNTAIN GOAT OUT!
