WD-45 slide-out rims
Offfishn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Offfishn Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 slide-out rims
    Posted: 16 Oct 2018 at 7:27am
Will the WD45 slide-out rims work on a D17?
54' WD45#160414 w/AC loader, 60" mower, sickle & 72" back blade.
In Michigan, out annoying the neighbors in something that has a motor in it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 8:36am
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Offfishn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 8:40am
Thanks Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 8:54am
They will work on a D-17 prior to series 3 models that have the same clamping method on the rail. Newer D-17's use different rails with the lock holes spaced differently. So, the answer is yes and no.
