Wd45 questions
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 questions
    Posted: 11 Apr 2012 at 8:09pm
Hi, I just got a wd45 and the spinout rims are stuck on it I was wondering what the best way to un lock them would be? Any suggestions thanks
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 8:17pm
If PB Blaster and a few hard raps on the end of the eccentric nut do'nt loosten them. the best way is take them off the tractor lay flat on the ground. take out the 8 bolts  holding the locks to the center and pound the center out. once it falls apart clean and loosten all the parts. antisieze the eccentrics and put back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 8:28pm
Thanks for the tip will definitely have to give it a try!!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 8:50pm
you dont need to remove the wheel.just start at yhe top eccentric,remove it,free it up,reinstall and move to the next one till all are free....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:30pm
That also sounds good I will try that first thank you!
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:42pm
Usually have to end up doing the steps that Dakota Dave described. With the eccentrics off the rim center you can lock them in a vice and hammer on the cam bolt with a impact back and forth until they loosen up. Experience has shown the bigger the impact the better too. Seen some that the 3/4 drive really struggled to loosen but persistence will pay off in the end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:50pm
Alright I'll just have to try it all . I've already snapped the drive off my breaker bar . But thank you for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:24am
Sometimes driving them back and forth with a really big hammer helps to loosen them so the impact wrench will turn them.
