WD45 oil bath air filter screen replacement |
Le Renard Farm
Topic: WD45 oil bath air filter screen replacementPosted: 02 Apr 2016 at 7:58pm |
Could you folks help me with my new 1956WD45? I am going to replace the screens in the oil bath air filter but am not sure how to get them out. Does the ring just under the screens come out? I tried but it didn't want to move so I stopped before I broke it.It is a United oil bath filter. Thanks in advance.
Posted: 02 Apr 2016 at 8:01pm |
You have to break thru several spot welds and then pull the ring free. There are three rolled up segments of wire mesh. I always unrolled each one and washed them out in solvent and reused them.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8574 |
Posted: 02 Apr 2016 at 8:04pm |
Agreed, Once you are able to get them out, you should be able to clean and reuse them.
Regards, Chris |
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 02 Apr 2016 at 8:21pm |
On one oil bath I took it off the tractor plugged the two air holes and filled it with diesel fuel soaked it for a day drained it out then tapped the assembly on the ground and blew it out with compressed air. I got it really clean. That one went into a different tractor and getting the screens out would have broken the housing for good in that case. On my d17 I did just break the spot welds. Soaking then in diesel works great to clean the screens.
MACK
Posted: 02 Apr 2016 at 9:27pm |
Role them up, soak them in gas then set them on fire. After they cool, unroll them, knock the soot out and reuse them. MACK |
Posted: 02 Apr 2016 at 9:34pm |
Well, I spent a lot of time on the last one I did (corn picker fuzz) and this pyro-technique thing sounds like a really good idea !!!!
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 03 Apr 2016 at 3:07am |
I put the whole assembly in the parts washer for a few days then rinsed it out good before draining and blowing air through it. last thing I did was spray a can of WD40 into it to be sure it wouldn't rust.
1957 WD45 dad's first AC
Le Renard Farm
Posted: 03 Apr 2016 at 3:56am |
Thanks everyone! I think cleaning of the screens on my tractor has never been done. The stuff I pulled from the intake tube was half an inch thick. I like fire and future service will probably include flames.
Le Renard Farm
Posted: 03 Apr 2016 at 4:12am |
Follow up question. Has anyone tried running the oil for the filter through a paper coffee filter to re-use? Thanks again.
Dan73
Posted: 03 Apr 2016 at 5:21am |
Just save used motor oil and put it in there you won't change it enough in a year to use up your used motor oil.
Lonn
Posted: 03 Apr 2016 at 5:37am |
It doesn't hold much new oil. Used oil contains acids that may rust components. Change the oil every 10 hours or so of use. If you can't do that then adapt a dry air cleaner to it and set the oil bath on a shelf.
Wink I am a Russian Bot |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3074 |
Posted: 03 Apr 2016 at 6:16am |
I think 10 hours is a little extreme unless its really dusty. I can look at mine in 20 hours and it looks almost new. I would say. Change when you change oil. Chen it some other times to make sure it's not to dirty. You know those old oil quarts that collect around a farm with torn off labels so your not sure what weight they are?? That's the oil I use in the bath
