WD45 Jumping Out of Gear Fix Question
leeave96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leeave96 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Jumping Out of Gear Fix Question
    Posted: 15 Nov 2015 at 7:31pm
Spent a little time tonight reading the sticky on 3rd gear jumping out of gear.
Replacing gears to fix worn down gears to fix the problem sounds pretty expensive, but if one avoids grinding gears, it's a long term fix - understood.
Question is - is the problem of jumping put of gear totally fixed?
Reason I ask is we have hills and while I really like the WD45, I am concerned from a safety standpoint with my kids driving, the tractor jumping out of gear - especially when being pushed with a baler or wagon with some hay on it.
When you replace these gears, how close to factory original is the tranny? Out of the box, would a new WD45 back in the day jump out of gear for any reason or was it only after operator abuse grinding gears that the problem arises?
On another note, if you rebuild/refurb the brakes, will they slide the tires or are brakes just a weak point on the WD45 - like my old MF50?
I'm considering other tractors in leu of the WD45 because of the jumping out of gear deal - but as I mentioned above, really like this design tractor for the era they were made and would like to add one to my fleet.
Any info is much appreciated.
Thanks!
Bill
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 7:51pm
Need to also replace couppler as well.
 I never thought brakes were a weak point on a WD45. If they are properly  adjusted they will slide the wheels. Alot of the time the stop on back shoe is not adjusted .  MACK
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 7:57pm
I drove a 15 year old WD when I was a whippersnapper and I don't recall having it ever jump out of gear. Ask Ted what the hills are like in Western Wisconsin.
Edited by DougS - 15 Nov 2015 at 7:58pm
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 9:25pm
Never seen a wd jump out of gear. Its the D series that is affected. And they dont usually pop out under load even if bad they "float" out of gear   like if you crest a hill and theres a second of no load on the gears. Now I did have a d14 that was so bad the gear would pop out as soon as you let out the clutch taking off. But I wouldnt worry about it. And my wd brakes are they best working brakes out of any tractor I have.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 9:53pm
WDs with the strait shift lever have a sliding gear transmission which did not have the jumping out of gear problem.  The late WDs and WD45s had the collar shift transmission which can jump out of gear caused mainly by grinding of gears over an amount of time.
I would check how bad the gears look and make sure that the gears do not have too much slop in between them that could cause them to jump out.  If the gears do not look too bad you can change the detent location allowing the fork to shift the collar farther onto the gear.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote leeave96 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 4:12am
Glad I asked this question. Learned something new with regards to the sliding gear tranny on the WD.
I'm guessing that with the similarities between the engine in the WD and WD45, that if one of these WD tractors had an engine rebuild, it got the WD45 pistons and with it similar/same power (maybe this was not physically possible) ?
If the WD's engine was rebuilt with the increased power of the WD45, could the sliding gear tranny withstand the additional load without premature wear or worse - outright failing?
Is the bottom line that the sliding gear transmission not going to pop out of gear going down hill with a load behind like the later helical cut transmissions?
Thanks again for the info.
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 4:31am
A new 200 would jump out of gear test driving it around the dealers lot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 6:38am
Bill
I've never heard of a WD or WD-45 transmission or power train failing. I'd say that a WD transmission could handle the extra power of a '45 engine. I believe the '45 had extra plates in the hand clutch, but that is the only thing they added.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 6:38am
As far as the brakes go when they are in good shape they work great. and yes you should be able to slide the wheels. The down side as far as I am concerned is when you need to install new brakes, that can become a full day's job even for an experienced wrench turner.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 7:56am
My WD45 has never poped out of gear and has neven been apart other than for inspection.  It was a well used tractor by my dad.  If treated well it will last a lifetime, abused and it will be short lived.  After replacing the brake shoes I can easily lock both rear wheels.  Replacing the brake shoes is not that hard as long as you don't think you need to get it done ASAP.  Mine took me a week to do of heating, oiling, heating, oiling and more heating.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 8:13am
First off guys we are talking about the WD45 with the last of tractors rolling off the line in 1957 and it's 2015 now, so you look back at all color tractors that age and they have had and might have again trans trouble. Next just installing a set of 226 pistons in a 201 will not gain HP but will lower the HP, it takes more than just pistons to get more horse power. I work on AC tractors day in and day out and can tell you fist hand I do less trans work and more engine work on them. Yes there's trans out running around with trouble but in my shop right now I have three WD45, one WD with a bent shifter trans, and a D19 and of them have good trans in them, In my barn I own three WD45's and a D19 with good trans in them too and have owned one D19 with gear trouble, so I think if you look around and do your home-work you will find a lot of good WD45 tractors still able to work on hills and not jump out of gear.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 8:31am
When we first got our new late model WD, with the curved transmission lever, sometimes it would get stuck in gear, 1st I think.
The dealer fixed it. I don't know what was wrong with it, I was only 11 or 12 then.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote leeave96 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 7:45pm
Thanks again everyone - I appreciate your replies!!!!!!!
Bill
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 8:22pm
Not to belabor the problem but one fix that I have not noted is that in the transmission main snap ring came in different thicknesses.  Sometimes we could add a thicker snap ring to take up the gear end play.  Sometimes that solved the problem.
Remember I am talking about the 50's and the tractors were very new then.  Now with age that may not work.  Also, if you grind the gears you are going to get rounded gear lugs and collars that will cause the popping.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 6:22am
We call them bluffs, but a lot of people who see them call them mountains.  You go STRAIGHT UP or DOWN, NEVER SIDEWAYS!!  You can hardly stand on them.  NOT fun at all.
If you want to check out a tractor to buy and want to see if it slips out of gear, just get it going down hill at full throttle and then push the throttle closed.  If it slips, you can fix it pretty easily, or you can just pass on that tractor.
This page was generated in 0.140 seconds.
