wd45 front-end play
wdforty5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 front-end play
    Posted: 13 Apr 2012 at 7:17pm
I took the caps off the hubs and was repacking the front bearings today.
I had the front end jacked up and noticed there was play in each spindle. I could move the wheel back and forth maybe an 1/8 of an inch top and bottom. Is there a bushing inside these?
Its 56 years old so im not expecting it to be tight... how much play before I need to tear it apart?
Thanks fellas,
Jim
"Old Iron...built to last"
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 7:25pm
Bushing is at the top and bottom of each spindle. The spindle shaft itself could be worn too.
Wink
I am a Russian Bot
