WD45 Front main seal number
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Front main seal number
    Posted: 12 Jul 2016 at 7:59am
Does anyone know the non-AGCO part number for the front main seal for a WD45? The good thick seal with the felt on the front.
I buggered mine up installing and want to get another one local from NAPA or somewhere.
Edited by Allis dave - 12 Jul 2016 at 8:00am
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 9:33am
napa only shows it in a front cover gasket set        part#FPG TCS3787
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 9:40am
Still only about $12 for the whole set as long as it's the think seal. I'll stop and get it ordered. Thanks
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 12:38pm
I have extra ones laying around
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 9:31pm
Dave,
Good that you decided to replace the damaged seal. Any improved installation techniques for the next one?
Looking forward to some pictures of this build too!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 11:11pm
When you get your new seal pack the back side of it full of grease (holds the spring in place) then I use shim stock rolled around the crankshaft to start it on the shaft and just past the pulley set-screw hole in shaft then remove the shim stock before installing the seal in cover, use a 6" long 1 1/2" PVC to tap the seal in cover. Did one Monday like I said above and have not bent one yet this way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 6:51am
Thanks Don, That's a good idea. Never thought about packing the seal full of grease to keep the spring in place.
From talking to Fred, I used the wrong seal. I used the WD seal with the outer felt and it's to small to fit the WD45 shaft. This gasket kit only came with this small seal and one that has the OD too big. I dig out my old leftover Victor Renz kit and it still have 2 seals left. The big and small one. with the correct seal missing (already used). Fred's sending me the correct seal.
This page was generated in 0.053 seconds.
