WD45 flywheel |
Post Reply |
Lew
Bronze Level Joined: 09 Jun 2017 Location: Buford, GA Points: 55 |
Posted: 21 Sep 2022 at 10:01am |
Upon tear down of my WD45 for refurbishment I found the bell housing seal 70224687 leaking causing the clutch area saturated. Inspecting the flywheel I found heat cracks that were all the way through the inside lip of the flywheel. My question, is this a major issue since the flywheel is solid about 1/2" back from the inside lip; I am going to have it resurfaced and the clutch disk contact is not close to this area. The tractor will be retired from farm work and used as a masterpiece of an aera gone by.
jvin248
Silver Level Joined: 17 Jan 2022 Location: Detroit Points: 278 |
. It's possible the retired tractor will go back into service if you sell it someday. Maybe repair the problem while you have everything apart? .
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7300 |
I would replace the flywheel since you are already in there.
MACK
Never saw one that didn't have heat cracks that had Ben used. MACK
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8143 |
What MACK says
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3646 |
If they're just hairline cracks, most will have those and just resurface it and use it...if real deep and opened up cracks, then replace it, if you think you need to...
Post Reply | |
