WD45 copper shims in bell housing and clutch q's
WD45 Aaron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Topic: WD45 copper shims in bell housing and clutch q's
    Posted: 08 Oct 2019 at 7:18pm
All,
I'm working on a WD45 that has a WD block in it. I pulled the block and found thin copper washers or shims laying in the bottom of the bell housing. I found 4 so far. Didn't measure them but they are in the neighborhood of 3/4 o.d. 5/8 i.d. and 15 thou thick give or take. I thought maybe something to do with the head gasket but don't know how they would have gotten there.
Also, is the flywheel and clutch the same between the WD and WD45?
Thanks,
Aaron
Machinery rescue for all things rusty or broken. Current residents include 3-1/2 WD45s, Oliver Row 77 gas, 88 diesel, Farmall super C, parts C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 8:39pm
Arron,
 The flywheels are not exactly the same. I dont remember the differences. I believe the 45 flywheel is a little heavier?? The experts will be along shortly.
I dont know what the shims are from?? I dont remember any shims like that in the 45 I worked on?
Regards.,
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 8:59pm
Flywheels are the same. Pressure plates could be different, but either will work. WD45D uses a different flywheel.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:17pm
Mack,
 Thanks! I thought there was a slight difference in the 45 to WD flywheel. I stand corrected.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 11:38pm
They went from the "vented" flywheel with the airspace behind the friction surface to the solid flywheel at some point on the gas. According to Agco parts book the flywheel went from part #70226760 to #70226868 at SN WD96714 which I would assume to be this change. The pilot bearing oil wick and cork plug in the crankshaft were also eliminated I believe with the change to solid flywheel. They fit and work the same on gas.
Edited by Bill_MN - 09 Oct 2019 at 11:40pm
