WD45 brakes
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 brakes
    Posted: 15 Jan 2012 at 9:07am
Make a loud grunt from time to time when i use them. Especially the  right one. Had them all out and apart, pads look fairly new,, drums worn evenly. Would brake lubricant take care of this noise?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:33am
Are you sure it's not the locks slipping on the spin-out rails?
With new brakes, you may be putting more pressure on them than before.
Of course, you should get a similar sound when you go forward if there is any load
or the clutch is released aggressively.
Just a thought!
This page was generated in 0.049 seconds.
