WD still overheating
Psdiesel350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Topic: WD still overheating
    Posted: 13 Sep 2017 at 10:44am
Hey all, ive got a wd that I just put a new radiator, new water pump, new thermostat and thermostat housing in, and it still over heats. Thr top of the radiator gets hot so I am assuming the t-stat is opening correctly. When it starts to over heat you can still touch the bottom radiator hose, its not that hot. Other than that it starts right up easy and runs good. I am kind if out of ideas.
Thanks
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:58am
Under load or anytime it's running?
Wink
I am a Russian Bot
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 11:03am
maybe bad temperature gauge
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 11:59am
I can just let it sit there and run and it will over heat. Brand new gauge and I confirmed with an infrared temp gun.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 12:02pm
leave a shop towel or rag stuffed into one of the hoses?
also years of rust and dirt can accumulate in the block.  was it flushed or cleaned out?
Edited by CAL(KS) - 13 Sep 2017 at 12:04pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 12:05pm
Does it boil over?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 12:32pm
leaking head gasket/cracked head
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 1:20pm
This. Take the radiator cap off and watch for bubbles in the coolant while the engine is warming up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 5:56pm
I ran it with the cap off the other day and watched it I didnt see anything really until it started get warmed up, but that was prolly around the temp the stat opened, and it wasn't bubbles, just the level fluctuated a little bit. No I didn't flush the block wasn't sure how to go about it. Any way to check the flow of the water pump?
Edited by Psdiesel350 - 13 Sep 2017 at 5:57pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 6:38pm
How hot is the temp gauge you put in it?
  You got the mechanical shutters still on the tractor??  and are they shut???
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 7:01pm
This ain't one of them you can put t_stat in upside down is it?
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 8:50pm
I changed out a rotten leaky radiator with brand new one out of box and 45 overheated,
since that was the onlly change I made, I suspected something with radiator. radiator shop was skeptical since radiator was brand new. when they called me to come and pick up radiator they handed me a ball of solder about the size of golf ball that was stuck in bottom of radiator, I think they had to unsolder bottom to get it out. that was 15 or 20 years ago and only problem I had.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 6:55am
i vote stopped up rad
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 11:07am
after running the engine how long does it take for coolant to come out?
At the point you have coolant coming out check the temperature with your inferred temp. gun. upper and lower hoses and engine block and head.
the other thing that you must consider is that there is no overflow/recovery tank on older tractors. the top of the radiator was designed to hold the expanded coolant, so if you fill the radiator full it will keep overflowing.
fill it up about 1" to 1.5" below the neck of the radiator.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 3:07pm
Did this tractor begin to overheat all of a sudden, or has it gotten worse over several years? If all of a sudden, then compression leak from a cracked head/leaking gasket. If over several years, your block is full of crud.
Edited by Bill_MN - 14 Sep 2017 at 3:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 8:30pm
Haven't had the tractor that long, had a busted up radiator when I got it that leaked real bad,so I couldn't even get it hot before, that is why it has a new one . then I checked the thermostat when it overheated and it didn't even have one, so I put one in. Then came the water pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 5:42am
I suspect that the previous owner ran it and got it too hot and warped the head.
Rick143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 12:55pm
If the previous owner removed the thermostat it's probably because he had overheating problems. Can you pressure test the cooling system?
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 8:50pm
ck the timing.....
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 8:29am
X 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 9:56am
I don't have a pressure tester,but I will get one . the thermostat was marked which way it went, pretty sure I got it in right. Might have to pull it apart and check. I think I also need to check the radiator, maybe its just not flowing, bad core in the new one maybe.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 7:43am
Where has the radiator been stored? Mice have a habit of nesting in the tanks. Take the lower radiator hose off and see how fast water runs through. Air lock? Doubt it but something to check.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 8:44am
Pull the thermostat put the housing on with out the hose start it up and let the water fly this will tell you if pump is pumping we had a new pump that the impeller was not thght as the cast impeller warmed up it got worse drove me nut (short ride)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 3:46pm
I think I got it figured out. I went to drain the radiator and nothing came out, I thought that's strange. So I pulled the petcock all the way out and still nothing so I dumped a whole gallon of coolant in and all it did was dribble out. I had to take the radiator complete out after over an hour and dump tje rest out of the filler. So guess ill get it to the radiator shop and see what's up.
This page was generated in 0.073 seconds.
