WD seat shock absorber replacement
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: WD seat shock absorber replacement
    Posted: 21 Dec 2016 at 2:44pm
Where to find a new one. Need just the shock part and bushings. Napa said they had nothing that matches.
Thanks
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 2:54pm
Leon - Jim, Tony, DJS, Norm Meinert, etc. all sell them including bushings.  There is a SN break I believe and 2 different ones.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 4:08pm
Like Mike said they all sale them, I get my parts from Tony.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 10:33pm
I got mine from Jim at OK tractor. He also had the bushings for the seat pivot point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 9:12am
Thanks guys, I'll look into them. I've done business with 3 of the 4 in the past.
Leon
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 9:37am
I think I have chased those shocks down in years past. Seems like I remember them as being the shortest stock shocks with loops on the ends, used in the fronts of 70s vintage Chevies cars and trucks. Could be the automotive shocks are stiffer than the original seat shocks. Not on any of my tractors.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 9:43am
Searching back forever I found:
WD seat shock
Posted: Jan 26 2011 at 8:13pm
Go to advance auto and get a Monroe 5752. The two piece rubber bushings are in HELP! set 31001. Don't let them cross the monroe part number to a gabriel shock, it won't work. Been there, done that. This info was good two years ago when I was putting my bench seat on my WD. Adam View Post
And
i think the napa number is LE100004 if my memory is correct.....
Gerald J.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 7:46pm
Also available from your AGCO dealer part # 70222488.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 8:27pm
Thanks Gerald, thats kinda what I'm looking for. I don't need the whole assembly just the shock. The ones on the parts sites here that I saw are more than I need. As far as being a little stiffer, I'm 250 plus, if it moves much at all it will be better than bottoming out every time I hit a hole. That's hard on the back.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 12:09pm
Leon, how are you going to get the caps for the spring to stay in place?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 4:53pm
One end is held in place by the shock itself, if the monroe shock is the same diameter and length, I'll spot weld the keeper ring (from the original shock that retains the spring cap) to the new monroe shock dust cover. That's the plan. I haven't actually looked at the monroe shock yet to see if it will match up.
All the other parts are good so I hate to spend $125 (with shipping) on the whole assembly when I just need a $25 shock.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 12:00pm
Thanks Leon, that's kind of what I had in mind too. I wonder if a guy could make something up fairly cheap that would work.  I know there are a lot of guys out there that would buy a kit if it was cheap enough...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 5:43pm
Ted,
I'm going to try to get to the parts store (monroe 5752, thanks Gerald) next week and I'll post what I find and what I do with it. It may take me a some time but I'll let you know how this works out. Having said that, I am not interested in making a kit for resale just info for those interested.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 5:55pm
Take the remains of your old shock with you and compare them.
Gerald J.
