WD restoration
Huolti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Topic: WD restoration
    Posted: 02 May 2021 at 2:05pm
Drained oil out of differential and pto housing. Want to refill now so is everything filled by filler plug next to hydraulic dipstick. There is another plug farther back towards the differential also. What is it for? Do you just fill to plug level or is there another way to check level?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 4:14pm
FILL THEM BOTH FULL !!! with the same kind of oil.  You should have removed three drain plugs starting at the PTO box and work to the rear. Takes about 4 gallons total.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 9:59pm
Those 2 plugs cover the same lube level but if you try filling through just one,it will take a long time because of a separate wall supporting shafts inside and the oil has to trickle through bearings. Fill to top then plug. You can safely use modern trans/hyd fluid with 821 specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 9:12pm
Get a owners manual for the WD. It is helpful
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2021 at 3:41pm
I have a manual but I could not see anything in there about fluid levels.Just tells capacities.
