WD piston interchange |
| Author | ||
AllAmericanWD
Topic: WD piston interchangePosted: 23 May 2012 at 5:46pm |
Hello all. I am the proud owner of a free Allis WD. It runs great now... but im planning on rebuilding the engine. What is the best piston upgrade for the money? WD45, D17, Sealed Power? Im not looking for a boat load of Hp but from what i have been told an upgrade would be worth the little extra. Thanks
| Sponsored Links | ||
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 23 May 2012 at 9:13pm |
most aftermarket sets are 4 1/8 overbore with flat top pistons as opposed to the stock dished pistons for higher compression, you would have to buy the matching sleeves though...stock 4" aftermarket pistons are hard to come by, might find a set of used M&W pistons
MACK
Posted: 23 May 2012 at 9:35pm |
If you use 45 or D17 you need to go to a WD45 crankshaft. MACK
mike a
Posted: 24 May 2012 at 8:04am |
replace that wd motor with one from a e-gleaner or d-17,you will be way ahead of the game.
CTuckerNWIL
Posted: 24 May 2012 at 8:32am |
If you use WD45 or D17 pistons with the WD crank, you will have a lower compression ratio and less power. The 45 and 17 have a 4.5 inch stroke so the pin to top of the piston is shorter.
David Maddux
Posted: 24 May 2012 at 9:50am |
For a good all around utility tractor, I would just stay with the available rebuild kit. dave.
Bill_MN
Posted: 24 May 2012 at 2:08pm |
I believe you could use flat top WD pistons with a WD45 crank, think it's about 8:1 compression
AllAmericanWD
Posted: 24 May 2012 at 7:11pm |
If I got a kit for my g201 with 4.125" bore pistons wouldn't that be same bore a g226? I was told I could just swap in wd45 pistons and sleeves in a wd. Its a good thing I asked. Where is the best place to buy a full rebuild kit including pistons, rings, sleeves, valve train, bearings, gaskets? Thank you for the help
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 24 May 2012 at 7:19pm |
WE HAVE REBUILD KITS OF YOUR CHOICE 1-574-342-4545
79fordblake
Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
Posted: 24 May 2012 at 7:21pm |
You can use WD45 pistons and sleeves in a WD. But you don't want to do that because it will actually lower your HP. The WD and WD45 both have a 4 inch bore. But the WD45 has a 4.5 inch stroke...the WD is only 4 inches. For good reliable power you can throw in a WD45 crank and D17 pistons and sleeves. |
AllAmericanWD
Posted: 24 May 2012 at 7:36pm |
Thats my bad. I should have said same cubic inch displacement not same bore. Im just going with an oversized wd piston. Any suggestions?
TREVMAN
Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Posted: 25 May 2012 at 10:02am |
1/8th over gives 213 cubic inches. Its the least pain for the most gain, Trev.
CTuckerNWIL
Posted: 25 May 2012 at 10:10am |
Got to the top right of this page and click on (parts etc) Sandy Lake, Tony C, OK tractor and Norm M are a few of the sponsors of this site that can help you out with a total kit. Best have the crank out and checked to make sure it doesn't need ground or maybe has already been ground once or twice. |
79fordblake
Posted: 28 May 2012 at 10:19pm |
While we are on this subject anybody know what the compression ratio would be if you used 4 1/8 flat top pistons with a WD45 crank? Idea of HP? Thanks.
CTuckerNWIL
Posted: 28 May 2012 at 11:09pm |
See Bill_Mn's post above. 1/8 over size probably won't make much difference. I would think you could get at least 50hp+ out of it. |
79fordblake
Posted: 29 May 2012 at 6:12am |
Somehow I skipped right over that post...I see it now...lol. |
