WD Leak Hose Bracket Mount
Too Tall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Topic: WD Leak Hose Bracket Mount
    Posted: 24 Jul 2026 at 10:56am
My WD leaks oil out of the four bolts that attach the hose bracket to the top of the hydraulic pump.  I put on new copper pressure washers and they still leak.  When I raise the hydraulic lever it leaks so much as to make the hydraulics unusable.  Thanks for help in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 11:05am
I should of said under the hose hook up part.  Those 4 bolts do not attatch the bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 11:58am
There is an O-Ring between the hold valve on top of the pump and the pump body. Twp bolts to remove the hold valve.
