WD hand cultch removal |
19F150
Joined: 13 Oct 2025 Location: eastern ia Points: 25 |
Topic: WD hand cultch removalPosted: 06 Jun 2026 at 4:00pm |
How do you remove hand cultch assembly?
Posted: 06 Jun 2026 at 6:18pm |
Battery box has to be removed and then the tractor split apart about 8 inches right there. Hand clutch comes up and out the hole directly underneath the battery box.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5914 |
Posted: 06 Jun 2026 at 6:23pm |
Page 34 in Part 1 of the Allis WD Service Manual gives a good explanation. G |
19F150
Posted: 06 Jun 2026 at 9:52pm |
how do you get the handclutch housing apart from the transmison
Posted: 06 Jun 2026 at 10:03pm |
Remove three 1/2" bolts on each side of the torque housing probably covered in dirt/grease. Remove two side frames bolts at the rear of each side frame. Brake pedal rods and springs disconnect. Steering wheel post disconnect from the transmission shift cover. PTO push/pull lever remove. Traction Booster signal linkage remove. Hand clutch clevis pin remove. That's about it I think. Roll the rear end away from the front. Use jacking under the PTO box. Use long redi-bolt thru the side frames ears to keep things under control. Why are you removing the hand clutch ??
19F150
Posted: 07 Jun 2026 at 10:25pm |
have all bolts removed and toque tube still won't come off from transmission
Posted: 07 Jun 2026 at 10:50pm |
Have you got the PTO shaft removed from the tractor ??
19F150
Posted: 08 Jun 2026 at 7:16am |
PTO shaft is off. torque moved about 1/4 inch is all
Posted: 08 Jun 2026 at 7:20am |
Hand clutch released?? or still locked in ? The bottle jack under the PTO box might have to be raised or lowered just a tick. You might be on a bind.
Edited by DrAllis - 08 Jun 2026 at 7:22am |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4242 |
Posted: 08 Jun 2026 at 8:44am |
is nt their a bolt inside the trans
LaJaMe
Joined: 14 Sep 2014 Location: wisconsin Points: 173 |
Posted: 17 Jun 2026 at 9:38pm |
As Dr Allis Says, Neewd to support the middle of the tractor.
