WD engine parts wanted |
Mike56073 ![]() Silver Level ![]() Joined: 14 Nov 2010 Location: New Ulm Points: 154 |
![]() ![]() ![]() ![]() ![]() Posted: 13 May 2012 at 7:13pm |
Looking around for a connecting rod bolt and nut(cotter pin style), and a front crankshaft pulley. The pulley needs to be off a wide front so the hand crank will work.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8616 |
Isn't the pulley the same? The wide front on my 45 has a different end on crank rod to work at an angle to the pulley.
No, the tractors with a narrow front use one part number, while the wide front and single wheels use another. I've got a narrow front pulley, but the tractor has been converted to a wide front and the owner wants the handcrank to work.
Can't speak to part #'s but I put a wide front under my originally narrow front 45 and the hand crank works the same pulley.
