WD electrical
Huolti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Topic: WD electrical
    Posted: 03 Sep 2017 at 1:44pm
In the process of restoring a WD. I removed the generator and limiting switch(I believe this is what it's called--small rectangular unit screwed on top of generator)for painting several months ago.I can not remember now how it was hooked up.There are 2 terminals on the switch and 2 on the generator. Thanks
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 1:52pm
The BAT stud on the generator goes to the GEN terminal on your "switch." This switch is called a cutout. The heavier of the two wires in the wire bundle goes to the other terminal on the cutout. The lighter of the two wires goes to the other stud on the generator.
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 2:04pm
The field terminal on the generator is hooked to the resistor terminal on the light switch. The other stud on the generator is hooked to the cutout, which has 2 connections, the second terminal on the cutout hooks to the wire running to the ammeter. This is from my memory, but I am pretty sure that is how it went, I will try to confirm it later, but I bet someone may have a diagram and post it for you soon.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
