WD air cleaner hose |
Matt Tallant ![]() Orange Level ![]() Joined: 15 Aug 2011 Location: Virginia Points: 691 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Jan 2018 at 6:05pm |
Do they need to have the spring inside?
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3930 |
None of mine have a spring inside.
acd17toy ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: USA Points: 723 |
My WD parts book show a spring in the air cleaner hose. If using a soft hose a spring is needed to prevent the hose from being sucked together when throttles is pulled wide open.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
My steiner replacement doesn't have a spring. It hasn't sucked in yet...
I would think if the hose sucks in that would indicate a restriction in the air cleaner.
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
The older style hoses were SO THIN that they sucked in. The newer ones are thicker. Lots of the older radiator hoses had springs in them, but none of them do anymore as they made them thicker. The older ones you could almost stick your finger through when they were hot. Felt like much. I haven't see one with a spring in it since,,,,,,,,,,,,,,,,,back in the 60s.
