WD 45 pan gasket ?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 pan gasket ?
    Posted: 30 Jul 2020 at 7:50pm
The pan gasket set has two little paper thin almost square w a notch. apx inch and half by inch and half. A not mechanical description is they look like a cow - legs down and head showing - the notch between the legs.
What do they do and where do they go?
Thanks, Larry Miller
I used to be young and stupid, now I am not young anymore.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:14pm
If you go to the Knowledge section and find Don Bradley's video of how to correctly install the pan gasket, etc.  He will answer all your questions.   Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:44pm
Thanks Den - I need to spend a week there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:07pm
Larry,
 I may be wrong but I believe your talking about the "F" gaskets? They go near the rear main on the aluminum rear seal plate I believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:25pm
You are right Sugarmaker - I had to come back and change those cow thingies to "F" gaskets.
Great video - I will go to the knowledge section before asking these kinds of questions again. Thanks again.
