WD 2nd gear problem |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6072 |
![]() ![]() ![]() ![]() ![]() Posted: 26 May 2010 at 10:52pm |
Hi All!
So, working on the WD project, she's running, took her for a drive. All seems to be working nicely with EXCEPTION of 2nd gear... When I put it in 2nd gear, it 'feels' normal, but when I roll forward a little bit, it kicks it out of gear... and if I HOLD it in, it 'bangs' on the shifter like... well... I dunno. But it doesn't like 2nd gear. Is there any wisdom available on this condition? if so, lay it on me! |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Do not use second gear until you get it fixed. Can't tell you much about what to do without knowing what transmission is in the tractror. Late WD's had a curved shifter with the constant mesh tranny developed for the WD45.
Yeah, there's no real risk of operating it in 2nd gear betwixt now and then... it simply won't. It's not knocking like a broken tooth, it literally kicks the shifter out.
I'm wondering if there's a bent fork in there... All other gears are working nicely, as do hand and foot clutches. What'd be the popular first step- pulling up the shift tower and looking down from the top? If I do, does the shifter need to be in any particular position before doing so? Patient: "Doctor, it hurts when I do this" Doctor: "Don't do that". |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
If I remember right you put it in 2nd gear or reverse to remove and install cover. 2nd gear is the one I used to put it in. Take a look-see.
Edited by Lonn - 27 May 2010 at 6:51am |
Wink I am a Russian Bot |
Still don't know what transmission you have????? Straight shifter or curved?? Edited by CTuckerNWIL - 27 May 2010 at 6:54am |
John (C-IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
Don't pull the whole shift tower as a first step! Pull the shift lever out of the tower first, it is a much simpler operation. You can tell a lot about what is going on by looking down the hole that the shifter came out of. My guess is that you have a problem with the detent balls on the slide rails, a worn/bent shift fork or even a bad gear. Use a large screw driver to shift the forks back and forth and observe the good parts vs any worn parts.
And. like Charlie said, it makes some difference which transmission you have. Edited by John (C-IL) - 27 May 2010 at 7:53am |
I have 3 of the gears that go in a straight shifter trans that are N.O.S. One of them is the input, one is the cluster gear, not sure which the 3rd one is. It's either 1/2 or 3/4. I'd make someone a good deal on them.
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Dave, if you have a curved shift lever, tranny uses the newer style constant mesh gears. Same type of tranny that you read about on here with "won't go into gear" or "jumps out of gear" issues, usually with a CA or a D series tractor. If it's a straight shifter, the tranny uses the older style gears that are pretty much bullet-proof....and the issue is most likely a shift tower problem.
WC, CA, D14, WD45
Sorry for not specifying- I didn't know there was a difference... After exploring my IT manual, I didn't see any indication of uniquity...
This is a straight shifter- straight up out of the transmission.... ![]() With an interesting, but I'm thinking aftermarket shift knob... Edited by DaveKamp - 27 May 2010 at 1:35pm |
Do like John said, take a look and see if anything looks worn. If you can't tell what the problem is by pulling the shifter, pull the cover and have a look.
