WC cultivator |
Ttague39B
Joined: 09 Aug 2025 Location: Tunkhannock PA Points: 62 |
Topic: WC cultivatorPosted: 23 Jul 2026 at 11:54am |
Hi all, I have a WD cultivator with the WC conversion and the manual talks about power lift. I would like to put it on my 37 WC if possible with no powerlift on it, would this be possible? And would i just follow the manual but ignore the powerlift hookup? Thanks.
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 631 |
Posted: 23 Jul 2026 at 1:09pm |
Not sure you can make that work, you either need the power lift or hydraulics, and you don't have that either on a WC. Someone else may chime in with an alternative but I don't think there are any other options. Let us know what you come up with.
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2375 |
Posted: 23 Jul 2026 at 6:41pm |
Not sure of that age, older ones if it was available but WC had a power lift for the cult. It mounted behind the transmission, our 39 model had one, used it for years.
Dennis J OPKs
Posted: 23 Jul 2026 at 6:58pm |
Not sure when it began on WC styled variety had the kick-out in the drive train so you raise the cultivator while not moving. Otherwise, on the old unstyled you were screwed and not able to raise it without moving-not a good design. They also had rear mounted lister/planters raised & lowered with the power lift. That's why the WD with hydraulics was a big leap.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2595 |
Posted: 24 Jul 2026 at 5:41am |
You need the power lift to... lift. Or jerry rig some kind of hyd setup. Gotta be able to lift it somehow. AaronSEIA
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11704 |
Posted: 24 Jul 2026 at 1:40pm |
CHECK SOME OF THE GUYS THAT ARE PARTSING TRACTORS OUT. They might have a WC that has the cultivator lifter on .
