WC cultivator
Ttague39B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Topic: WC cultivator
    Posted: 23 Jul 2026 at 11:54am
Hi all, I have a WD cultivator with the WC conversion and the manual talks about power lift. I would like to put it on my 37 WC if possible with no powerlift on it, would this be possible? And would i just follow the manual but ignore the powerlift hookup? Thanks.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2026 at 1:09pm
Not sure you can make that work, you either need the power lift or hydraulics, and you don't have that either on a WC.  Someone else may chime in with an alternative but I don't think there are any other options.  Let us know what you come up with.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2026 at 6:41pm
Not sure of that age, older ones if it was available but WC had a power lift for the cult.  It mounted behind the transmission, our 39 model had one, used it for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2026 at 6:58pm
Not sure when it began on WC styled variety had the kick-out in the drive train so you raise the cultivator while not moving.  Otherwise, on the old unstyled you were screwed and not able to raise it without moving-not a good design.  They also had rear mounted lister/planters raised & lowered with the power lift.  That's why the WD with hydraulics was a big leap.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 5:41am
You need the power lift to... lift.  Or jerry rig some kind of hyd setup.  Gotta be able to lift it somehow.
AaronSEIA
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2026 at 1:40pm
CHECK SOME OF THE GUYS THAT ARE PARTSING TRACTORS OUT. They might have a WC that has the cultivator lifter on .
