wanted Wd45 & C parts
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Topic: wanted Wd45 & C parts
    Posted: 25 Jun 2026 at 8:08pm
Will be at Penfield GOTO on Sat.
WD45 4 bolt wide front Bolster . just bolster not complete front end. casting between frame rails.
very nice C grill.
3 hole or 5 hole pan seat. no welds
Steel wheeled C or B, tall pipe air cleaner.
Also looking for a CA Hydraulic pump  delete cover Pt # 225195 for covering the Hyd  opening. Cover on it's way** Thanks Paul B
(Just added.)  C draw bar brackets,   Ca snap coupler release lever.  WC brake lever extension clamps.4 needed.
Thanks Bill P.
send a PM. or
Text. 734+347+5426
Edited by BILLP-SE-MI - 05 Jul 2026 at 8:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2026 at 8:16pm
I won't be a Penfield, However if you don't find the CA hydraulic pump delete I have a few.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2026 at 9:48pm
have 4 bolt steering block
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 10:33am
sent PM
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 6:13pm
I should have front end also
