  FAQ FAQ  Forum Search Search  Events Events  Register Register  Login Login
wanted...pto generator
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: wanted...pto generator
    Posted: 23 May 2010 at 4:45pm
Looking for a 15 to 25k pto generator within a 2 or 3 hour drive of
Moscow Mills (east-central) MO. 636-368-2363
Thanks
Leon B
Edited by Leon B MO - 23 May 2010 at 4:46pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 5:22pm
Leon, I have a 25KVA  Dayton PTO generator, I have used it two or three times, Works grate but the book says it needs 45 HP to run it and all three of my WD45's have tried to and they just don't have the Hp to get it done! I say if you pull max KVA's out of it you will need a D19 or bigger, That's way the 4020 LPG is sitting in the back. lol
I got it used off Evel-Bay two years back.
Don
I need to say that it is not for sale , I was just letting you know not to get a big unit and try powering  it with a little tractor.
Edited by Don(MO) - 23 May 2010 at 8:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:17pm
Don, is it for sale? I have a WD with a Gleaner engine in it, or even the U or UC. I'll bet a load would make those old girls bark. I only want to be able to use it for some mobil welding jobs and to run the house when the electric is out. My electrician said I could get by with 15 to 18k generator if I chose which breakers to keep on. I have an all electric house but also have ground sorce water furnace and my electric backup elements have never kicked on. So I could run the furnace for a while and then water heater and the deep well. Specs say about 2hp per k of generator, so I should be able to run my house with one of my tractors and do mobil welding with the CA's(I ran dad's 18k and Lincoln 250 buzz box, it made the CA bark but welded wonderful.)
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:20pm
I just read your post again and see it's not for sale, thought I was going on a road trip.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:26pm
No Leon Is not for sale, Sorry about the way my post came across like that. I was just letting you know that my 25 KVA unit needed more HP than my old WD45 had in her. LOL But  the U or UC might pull a 25 KVA unit.
Don
N.C. Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N.C. Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:52pm
A U or UC with more PTO horsepower than a WD45? That must be a tired 45?
'57 WD45, '47 B, Massey-Harris 60 SP Combine
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 10:08am
Our 20 KW will kill a D17 before tripping the breaker.
