Valve Clearance |
| Author | ||
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5359 |
Topic: Valve ClearancePosted: 11 Jan 2026 at 1:03pm |
Working on my D14, replacing the valve cover and manifold gaskets. I am going to check the valve clearances and make any adjustments if necessary while I have the valve cover off. Since many components have been removed to prep for paint I can’t start the engine to get it to operational temperature as the manual recommends. Question is, is there a big difference checking them cold versus hot? .012” is what the book calls for. Obviously much easier to check them at this point with all the sheetmetal off, or should I wait until I put it back together to get it up to operational temperature?
| Sponsored Links | ||
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5178 |
Posted: 11 Jan 2026 at 2:05pm |
I always set them cold, and add about .002" to the hot spec. I've never felt I could go through them all quick enough hot to be the same temp from start to finish.
AC720Man
Posted: 11 Jan 2026 at 2:36pm |
I agree with you ED, it wouldn’t be consistent on a hot engine by the time you went through them all. So you would set them at .014”? The book gives a range of .012”-.014”.
Thanks |
injpumpEd
Posted: 11 Jan 2026 at 2:40pm |
Probably so. Intake lash usually tightens up over time, exh usually gets loose.
Les Kerf
Posted: 11 Jan 2026 at 3:04pm |
I would set them cold at 0.014" and forget about it. Back in the day I set the valves on my 1955 Ford with the Y-block 272 hot and running. What a mess! Son-in-law has a 53 F-350 with a 292 and I just adjusted them to zero clearance cold and then opened them up 1/4 turn. It works out the same
![]() Edited by Les Kerf - 11 Jan 2026 at 3:07pm |
AC720Man
Posted: 11 Jan 2026 at 4:39pm |
The oily mess was my other concern Les. I’ve adjusted cold on my D17D and other tractors I have but just wanted to get some other opinions. I don’t recall adding any though which I understand why it’s suggested. Thanks to both of you.
Edited by AC720Man - 11 Jan 2026 at 4:42pm |
Clayfoot
Joined: 23 Sep 2024 Location: Southern Ohio Points: 47 |
Posted: 11 Jan 2026 at 5:56pm |
Has anyone done a running lash adjustment on these, or do you get too much oil spray?
Edited by Clayfoot - 11 Jan 2026 at 5:56pm |
Jim.ME
Posted: 11 Jan 2026 at 8:15pm |
With a .012 to.014 range l would go .002 over mid-range (.013) and set them at .015 cold.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3153 |
Posted: 11 Jan 2026 at 9:00pm |
For some reason seems like valves get adjusted to tight on old tractors,with low RPM motors like in old tractors I've found a little loose is better than a little tight.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5116 |
Posted: Yesterday at 6:03am |
DrAllis suggested .015 cold several years ago. Since then, I have always used this setting. No problems, so far.
Posted: Yesterday at 6:25am |
.015" COLD for intakes and exhausts on all West Allis built 4 cylinder engines. While some want to re-invent the method, this has worked for 50 years for me and is EASY to remember and do.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4216 |
Posted: Yesterday at 6:58am |
I've seen it done on V-8's with hydraulic lifters. I can not imagine trying to do it on a mechanical lifter cam. I hate 'hot' valve lash specs. Like Ed said, who's fast enough to get them all set before the engine is cool? I recently set lash on my Farmall 450, they have a hot spec. So I added .002" and set them cold. Will check them after first run at head re-torquing time. Also put the head on the 756 gas yesterday, another hot spec. Will do same procedure as the 450.
IBWD MIke
Posted: Yesterday at 9:56am |
I had a learning experience this morning I thought I would relate;
Reading the manual for the 756 where it talks about valve lash it has a footnote. It says, "engine warm means any temperature above 32 degrees F.". Well, that's a bit different than my thinking of warm! Guess I'll have another look at the 450 manual and see if it's the same. May be tightening them up a couple thousandth's. I have no idea if Allis, or any of the other manufacturers for that matter, used this description.
Les Kerf
Posted: Yesterday at 11:35am |
My late Father-in-law had a handful of old beat up feeler guages from his years as a service station mechanic back in 1950's-60's. As I mentioned above, I have done it on old Fords in my youth but have since been enlightened
![]() Edited by Les Kerf - Yesterday at 11:37am |
injpumpEd
Posted: Yesterday at 2:31pm |
When I see the valve lash specs, they usually say cold, as in ambient temp, or hot as in engine up to operating temp. I have never seen one give a spec for actual cold temps.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1551 |
Posted: Yesterday at 4:14pm |
I have always done valve sets at ambient temperature. Add .002 to the spec as all others have said!
AC720Man
Posted: 18 hours 40 minutes ago at 10:19pm |
I set them at .014” today thinking the thread was done, checked at 8 am. Only 3 valves needed a slight adjustment.
Edited by AC720Man - 18 hours 39 minutes ago at 10:20pm |
Ed (Ont)
Posted: 9 hours 15 minutes ago at 7:44am |
Should be good.
