Valve Clearance |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5358 |
Topic: Valve ClearancePosted: 10 hours 11 minutes ago at 1:03pm |
Working on my D14, replacing the valve cover and manifold gaskets. I am going to check the valve clearances and make any adjustments if necessary while I have the valve cover off. Since many components have been removed to prep for paint I can’t start the engine to get it to operational temperature as the manual recommends. Question is, is there a big difference checking them cold versus hot? .012” is what the book calls for. Obviously much easier to check them at this point with all the sheetmetal off, or should I wait until I put it back together to get it up to operational temperature?
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5176 |
Posted: 9 hours 9 minutes ago at 2:05pm |
I always set them cold, and add about .002" to the hot spec. I've never felt I could go through them all quick enough hot to be the same temp from start to finish.
AC720Man
Posted: 8 hours 38 minutes ago at 2:36pm |
I agree with you ED, it wouldn’t be consistent on a hot engine by the time you went through them all. So you would set them at .014”? The book gives a range of .012”-.014”.
Thanks |
injpumpEd
Posted: 8 hours 34 minutes ago at 2:40pm |
Probably so. Intake lash usually tightens up over time, exh usually gets loose.
Les Kerf
Posted: 8 hours 10 minutes ago at 3:04pm |
I would set them cold at 0.014" and forget about it. Back in the day I set the valves on my 1955 Ford with the Y-block 272 hot and running. What a mess! Son-in-law has a 53 F-350 with a 292 and I just adjusted them to zero clearance cold and then opened them up 1/4 turn. It works out the same
![]() Edited by Les Kerf - 8 hours 7 minutes ago at 3:07pm |
AC720Man
Posted: 6 hours 35 minutes ago at 4:39pm |
The oily mess was my other concern Les. I’ve adjusted cold on my D17D and other tractors I have but just wanted to get some other opinions. I don’t recall adding any though which I understand why it’s suggested. Thanks to both of you.
Edited by AC720Man - 6 hours 32 minutes ago at 4:42pm |
Clayfoot
Joined: 23 Sep 2024 Location: Southern Ohio Points: 47 |
Posted: 5 hours 18 minutes ago at 5:56pm |
Has anyone done a running lash adjustment on these, or do you get too much oil spray?
Edited by Clayfoot - 5 hours 18 minutes ago at 5:56pm |
Jim.ME
Posted: 2 hours 59 minutes ago at 8:15pm |
With a .012 to.014 range l would go .002 over mid-range (.013) and set them at .015 cold.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3153 |
Posted: 2 hours 14 minutes ago at 9:00pm |
For some reason seems like valves get adjusted to tight on old tractors,with low RPM motors like in old tractors I've found a little loose is better than a little tight.
