Valve Clearance
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Valve Clearance
    Posted: 6 hours 23 minutes ago at 1:03pm
Working on my D14, replacing the valve cover and manifold gaskets. I am going to check the valve clearances and make any adjustments if necessary while I have the valve cover off. Since many components have been removed to prep for paint I can’t start the engine to get it to operational temperature as the manual recommends. Question is, is there a big difference checking them cold versus hot? .012” is what the book calls for. Obviously much easier to check them at this point with all the sheetmetal off, or should I wait until I put it back together to get it up to operational temperature?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 21 minutes ago at 2:05pm
I always set them cold, and add about .002" to the hot spec. I've never felt I could go through them all quick enough hot to be the same temp from start to finish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 50 minutes ago at 2:36pm
I agree with you ED, it wouldn’t be consistent on a hot engine by the time you went through them all. So you would set them at .014”? The book gives a range of .012”-.014”.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 46 minutes ago at 2:40pm
Probably so. Intake lash usually tightens up over time, exh usually gets loose.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 22 minutes ago at 3:04pm
I would set them cold at 0.014" and forget about it. Back in the day I set the valves on my 1955 Ford with the Y-block 272 hot and running. What a mess!
Son-in-law has a 53 F-350 with a 292 and I just adjusted them to zero clearance cold and then opened them up 1/4 turn. It works out the same Tongue
Edited by Les Kerf - 4 hours 19 minutes ago at 3:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 47 minutes ago at 4:39pm
The oily mess was my other concern Les. I’ve adjusted cold on my D17D and other tractors I have but just wanted to get some other opinions. I don’t recall adding any though which I understand why it’s suggested. Thanks to both of you.
Edited by AC720Man - 2 hours 44 minutes ago at 4:42pm
Clayfoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clayfoot Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 30 minutes ago at 5:56pm
Has anyone done a running lash adjustment on these, or do you get too much oil spray?
Edited by Clayfoot - 1 hour 30 minutes ago at 5:56pm
