Usual Jumping Out Of 3rd Gear ? |
Page <12 |
Posted: 05 Jul 2017 at 10:27am |
There is no "adjusting" the detent. You have to remove the shift cover and relocate the detent notch a bit for a deeper shift stroke and weld up the other end of the notch. A 3/8" carbide burr die grinder is what I use and a calipers to measure where I want it located. It's not a job for a beginner in my opinion.
lawhk
Joined: 10 Jan 2014 Location: Lkport, mb. Can Points: 1 |
Posted: 11 Jan 2018 at 12:56pm |
Hi I'm looking for someone who has taken these tractors apart to repair the trans, and am wondering if there are any particular things to watch for. My unit is a 1954 wd45 that jumps out of 2nd.
Jack(Ky)
Posted: 25 Apr 2018 at 9:24am |
I take the detent shaft out and tig weld one end of the groove up and take the same amount out of the other end and it lets go in gear deeper. If they had done this when building them we wouldn't be having so many of these conversations.JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
JerryKy
Joined: 27 Aug 2016 Location: Northern KY Points: 1 |
Posted: 12 Jul 2022 at 6:39pm |
I would like to communicate with Jack (from KY.) My email is heistjerry@gmail.com
I have a D-15 with a few problems. |
Jack(Ky)
Posted: 14 Jul 2022 at 9:14am |
JerryKy. Just give me a call. 270-427-0535. If I don't answer leave a message.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25489 |
Posted: 23 Aug 2025 at 6:31am |
Did the same on my D-14 a while back, tweaking the detents fixed the 3rd gear issue for good. Added the Charlyn setup too, makes a world of difference when working with a loader. Definitely worth the upgrade.
Page <12 |
