Two way hyd cylinder and a 59 Allis D17
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Two way hyd cylinder and a 59 Allis D17
    Posted: 19 Mar 2012 at 11:36am
Hi-I want to use this cylinder on this tractor but it has just the one port.  I'll use that for the lift side.   What do I do with the other hose/port?
I've heard of just venting it to the atmosphere.  How does a guy put a "breather" on that end?  Where can I get one of these "breathers"?
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 12:05pm
DON"T USE A CYLINDER WITH BOLT ON ENDS,Prolly low pressure,might blow apart!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 5:02pm
You probably need a setup like someone put on my D17. It has what looks like might be a custom made steel return line along side the original steel supply line and a pair of spool valves. For supply they just plugged into the hyd port on the original transport valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 5:14pm
I have used an Oliver cylinder on my 45 many times with no problem, except for being a little slow. To vent it and keep dirt from being sucked back in use a cintered muffler.
http://www.fastenal.com/web/products/detail.ex?sku=0469591
Roddo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 7:09pm
+1 Charlie!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 4:33am
I used low pressure cylinders all the time til I blew one apart!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 7:46am
If you move to the hold position once the cylinder is extended, you won't blow the cylinder. If you leave it in the up position and the pump doesn't bypass, it can hammer till either the cylinder lets go, the pump bypasses or something else breaks. All hydraulic components are tested way beyond their advertised limits.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 8:22am
Northern Hydraulics (and I'm sure others) sells breathers to convert two way cylinders to one-way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 10:17am
Charlie,every once in while I forgets to think!LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 1:00pm
Wife says the same about too often lately:)
