Transmission and differential oil for 170
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Transmission and differential oil for 170
    Posted: 04 Mar 2019 at 2:31pm
My manuals don't tell me which oil to use for my One Seventy.  Can someone give me a reference or tell me what you use?  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 2:54pm
Looks like it is 90W.  Thanks.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 3:53pm
    Howdy Farrell,
    Just got done changing oils this winter in my 1967 One Seventy. Oem manual says 24 qts for transmission and 26 qts for hydraulic system. Manual also says use Allis Chalmers special fluid! But after much consideration I put in trans/hydraulic oil in both. Hope this helps
    Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 5:28pm
The one we used to have we used Ac 821 hyd oil in it , both compartments
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 5:32pm
Most any Universal TransDraulic oil has the Allis 821 spec listed, last I looked. It's all you need for both.
